LS-T help...horrible idle.
Old Aug 19, 2012 | 05:19 PM
mvang001's Avatar
Default LS-T help...horrible idle.
Hey all, just recently started to have a lot of idling issues with my ls-t. She idles real bad. I've cleaned IACV, check all vacuum for any leaks, made sure timing is correct, etc etc. I'm at a stand still now and STUCK. I'm guessing it may be Crome and time for a new ems, but I'd rather be safe than sorry. Any help is appreciated. Click on pic below for video
Old Aug 19, 2012 | 05:25 PM
Turbo-LS's Avatar
Default Re: LS-T help...horrible idle.
have you confirmed the IACV is good ? have you set the idle screw with the IACV disconnected ? When was the last time you check cam timing and also valve lash adjustment ?
I wasnt able to see the video but those are some suggestions
Old Aug 19, 2012 | 05:29 PM
LightningTeg's Avatar
Community Builder
Injector battery offset correct? Wideband?
Alot of things here. I found it easy to start with a basemap from Xenocrons BIN dump on their site and go from there when using Crome
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Started having the problem after what? How is your tune/wideband readings? Have you taken a look at your spark plugs at all? The wires? It's not Crome, haha... even though its not great.
Old Aug 19, 2012 | 05:37 PM
EsotericImage's Avatar
Retired Moderator
Ive had idle issues with crome..
switched to neptune and did nothing to the engine, idle was fixed
Old Aug 21, 2012 | 07:48 AM
mvang001's Avatar
currently don't have wideband so will purchase one and get car retuned. Will check cam timing. Valve adjustment already done. will update later. Thanks for the recommendations all. Hopefully I can get this thing fixed.
nekoabandoned
Feb 16, 2009 10:13 AM
SoCar
Apr 20, 2004 04:35 PM
speedaccordinly24
May 21, 2003 06:43 PM
Luke J
Apr 13, 2003 06:05 PM
vti-R
Jun 21, 2002 08:01 PM
