Pic request log manifold intercooler piping
Old Sep 11, 2012 | 07:15 AM
t3gav's Avatar
Default Pic request log manifold intercooler piping
Did a quick search but most pictures are with the bumper on, can anybody share a pic of there log setup on a B series, I want to see how you plumb the intercooler in... Can you get the intercooler piping between the block and the exhaust downpipe or do they usually run in front?
Old Sep 11, 2012 | 12:13 PM
EsotericImage's Avatar
Retired Moderator
Default Re: Pic request log manifold intercooler piping
depends on the intercooler you use and if you mount the turbo with a driver or passenger side exit.
Old Sep 12, 2012 | 12:26 AM
t3gav's Avatar
Sorry I meant with the compressor on the passenger side, i.e. how do you route the ic pipe work over to the drivers side when the compressor housing is on the passenger side?
Old Sep 12, 2012 | 12:44 AM
wantboost's Avatar
Who is Mr Robot?
the same way you would if it were on the drivers side... it just has a longer straight section before the turn to the compressor housing....
Old Sep 12, 2012 | 06:39 AM
t3gav's Avatar
Thanks that's what I thought but just wanted to clarify there isn't room for the ic pipe to go out the compressor downwards and then behind the exhaust downpipe i.e. between block and downpipe.
Old Sep 12, 2012 | 07:52 AM
Retired Moderator
you dont want the charge piping anywhere near the downpipe.
but if im mis understanding what your trying to do, show a pic and edit it with some arrows of what your trying to do.
Old Sep 12, 2012 | 08:46 AM
kyden's Avatar
i assume you have an a/c compatible manifold? then it should go in front of the downpipe (if the downpipe was made correctly).
Old Sep 12, 2012 | 05:15 PM
wantboost's Avatar
Who is Mr Robot?
the charge piping always goes in front of the downpipe regardless.... theres never room for behind.
Old Sep 12, 2012 | 05:58 PM
grumblemarc's Avatar
The Grumpiest
What does the manifold have to do with the IC piping? Just trying to understand the title of the thread.
Old Sep 12, 2012 | 06:04 PM
wantboost's Avatar
Who is Mr Robot?
same here
Old Sep 13, 2012 | 12:33 AM
t3gav's Avatar
Sorry maybe I should have explained better, I have very limited room and wanted to know if it's possible to route the ic piping behind the downpipe when using a log manifold, as I suspected this is not the case, for example http://jamesfawcett.co.uk/cms/index....id=7&Itemid=11 you can see the ic piping goes down and around to get to the intercooler not in front Anyway thanks for the replies
Old Sep 13, 2012 | 12:51 AM
wantboost's Avatar
Who is Mr Robot?
routing the downpipe further out from the block really wont work and will give you less clearance and will cause you to make some funky bends in the intercooler piping. air doesn't like to turn... for every turn in the piping you lose 1% efficiency in flow.
its best to route it in front of the downpipe..
any pictures of your specific application?
Old Sep 13, 2012 | 02:54 AM
t3gav's Avatar
Thanks for your help, no pics as yet as I'm still deciding on what kit to buy and checking it'll fit before I order it Phil at Spoolin has been really helpful too.
Old Sep 13, 2012 | 02:58 AM
The Grumpiest
Man. It's intercooler piping. You're making this waaaaay more complicated than it has to be. Once you install everything, you'll see that your options are limited.
Old Sep 13, 2012 | 05:42 AM
t3gav's Avatar
Ha ha I know that's why I wanted to get the most compact solution i.e. log or other manifold, thanks anyway.
Edit, your link helps https://honda-tech.com/forums/forced-induction-16/complete-how-turbocharge-your-honda-rep-ing-hypnotik-speed-1263795/ first pic gives me an idea of clearance.
scia220
Mar 31, 2011 04:30 PM
Project99EK
Oct 22, 2006 10:57 AM
0ptimus prime
Welding / Fabrication
10
Mar 6, 2005 06:30 PM
deeweezy
Sep 14, 2003 11:32 AM
