any tips on setting launch control s300 d16t
Old Sep 8, 2012 | 05:06 PM
v8killaz's Avatar
Default any tips on setting launch control s300 d16t
running a d16 vitara motor. trying to set lc(launch control) to build some boost off the line. i have it set to
-15 timing +15 fuel at 4500rpm but no boost
i dont know really what to do without blowing my motor. any insight would help.
should i use more timing less fuel or less timing more fuel.
Old Sep 8, 2012 | 05:12 PM
phaphon's Avatar
Default Re: any tips on setting launch control s300 d16t
man i dont even know how to set launch/anti lag on my car . bump for some info
Old Sep 9, 2012 | 08:37 AM
v8killaz's Avatar
noone
Old Sep 9, 2012 | 08:45 AM
mtber's Avatar
Make sure your activation rpm is around 500-300 rpms lower then your launch limiter rpm.
Try -25 ignition and 40 for fuel.
Experiment with rpm, retard & fuel values until you achieve the launch you are looking for.
Old Sep 9, 2012 | 10:53 AM
justYncredible's Avatar
It's wU to the sOLdiEr!
whats a good value to start with it? i want to set mine up as well, just need a low value to start with kind of like how i set my boost solenoid
1000cc
t3/t4 garrett 57 trim 63 ar
ramhorn
just a little info
Old Sep 9, 2012 | 10:56 AM
v8killaz's Avatar
1000cc
ramhorn
just a little info
you quoted the answer
thanks mtber for the info. now without a egt gauge to moniter exhaust temp how should i go about doing this safely wihtout blowing my turbine to peices. im assuming the afr will go full lean
Old Sep 9, 2012 | 11:10 AM
turbohatch96y7's Avatar
I think the A\F will go full rich. Haven't messed with mine but I have mine setup the same as mtber.
Old Sep 9, 2012 | 12:03 PM
lol,
is the retard value automatically negative or should i put the "-" sign
Old Sep 9, 2012 | 02:46 PM
v8killaz's Avatar
yes mtber numbers made boost very quickly and biug fireballs out of my exhaust.. i went with -20 and 30 for fuel just to stop that. i guess for a race car it would be fine but im running smaller drag radials and only need about 10psi off the line. im running 20psi total. main concern is breaking the turbine and in turn ******* my motor up since this is my dd.
lol,
hondata states to type - first i beileve. i forget what mine was set to
Old Sep 9, 2012 | 03:00 PM
mtber's Avatar
Your welcome :-)
EL TYPE R
Mar 7, 2013 09:33 AM
E85B18
Jul 22, 2010 03:21 PM
Garage 808 Hatch
Mar 13, 2008 08:26 AM
Pippen_001
Jul 26, 2007 01:24 PM
mike93eh2
Nov 16, 2006 08:15 AM
