engine will not rev as high in high boost
Old Sep 19, 2012 | 02:07 PM
ashb82's Avatar
Default engine will not rev as high in high boost
I have a f22a made 460whp at 23psi. when i dynoed i made power from 5k to 8k when the boost is @ 8 psi to 15psi. once i go over 15 psi or 350hp my car will not pull to 8k. it just get rich and you have to take out alot of fuel. i am thinking its the intake manifold. things i have tried different tuners lol, spark plug gaps, heat ranges and brands, racing fuels, down pipe sizes, turbos, and cam retard.
here is a list of parts i have on my car.
bisimoto pro springs
bisi 1.2 turbo cam.
h22 h beam rods
wiseco pistons
ram horn manifold
hx35 hx40 61mm turbo
3" down pipe and open exhaust
stock intake (butter flies removed)
stock tb
1000cc fic
Old Sep 19, 2012 | 02:42 PM
ashb82's Avatar
Default Re: engine will not rev as high in high boost
you can see it here this is a 17psi and 19psi pull. if i would have done a 12 psi pull the hp would have climbed to 8k
Old Sep 19, 2012 | 03:37 PM
Muckman's Avatar
Moderator in Chief
It looks like your hitting a wall pretty hard. Despite boosting more its clearly not flowing more. Hows your air filter. Have you ever tried making a pass without it?
Old Sep 19, 2012 | 03:58 PM
DraginX's Avatar
Might want to change your fuel filter, I've seen that happen before when the filter is partially clogged.
Old Sep 19, 2012 | 05:25 PM
ashb82's Avatar
those are with out air filter. i dont see how it could be the fuel filter because it not starving for fuel.
i am hoping its the stock intake and throttle body. the f22 has a pretty restrictive intake.
its in a EG i went 7.0 @103 in the 1/8th.
Old Sep 19, 2012 | 06:44 PM
vwbased's Avatar
have a nice day
Old Sep 19, 2012 | 06:56 PM
ashb82's Avatar
its a sohc i cant retard the intake
Old Sep 19, 2012 | 08:45 PM
Muckman's Avatar
Moderator in Chief
HA. Time to try a new cam then.
Old Sep 20, 2012 | 02:18 AM
ashb82's Avatar
the cam is mild its like a 268/262 duration. i think i am going to try a delta regrind. delta 282 duration they are 96$ to regrind. i have seen some good results in a dsm from delta. if that dont pull like i want then i will save up for a bisimoto 2.4 cam.
Boosted67
Aug 26, 2016 07:04 AM
Newsom91
Sep 4, 2009 10:42 PM
DJaeMac
Honda Civic (2001 - 2005)
10
Sep 27, 2007 10:27 AM
racinskittle
Sep 27, 2003 08:01 PM
OKSolSi
May 20, 2002 04:31 PM
