issues at vtec
Old Sep 3, 2012 | 01:41 PM
sanman000719's Avatar
Default issues at vtec
so my car runs just fine untill 5400 rpm's (vtec) then it sputters and cuts in and out. on the dyno it was flawless and made 755@32 psi. it doesnt matter if im on it or slwoly rolling, but as soon as vtec hits it has issues.
what do you guys think solonoid<<<<<<spelling lol
Old Sep 3, 2012 | 01:57 PM
Turbo-LS's Avatar
Default Re: issues at vtec
if only WOT pulls were made then the rest of vtec might not be tuned properly
Old Sep 3, 2012 | 02:07 PM
this is also an issue now at wot sorta
it ran extremely well yesterday at 12psi went 10.8
turned it up t0 26psi and not good at all, and then dropped it to 20psi and same thing
Old Sep 3, 2012 | 02:22 PM
Turbo-LS's Avatar
What ignition? What plugs? Sounds like spark blow out is a possibility
Old Sep 3, 2012 | 02:25 PM
pro14 with cops ngk vpower 10's gapped at .18
Old Sep 3, 2012 | 02:27 PM
of course i meant .018
Old Sep 3, 2012 | 02:29 PM
Turbo-LS's Avatar
What are they AF looking like at that boost level? Have you pulled the plugs and inspected them? Need to find out if it's detonation or blow out? What fuel are you running? Give a complete breakdown of the setup so others. An help better diagnose
Old Sep 3, 2012 | 02:34 PM
e85 plugs look fantastic actually
15.66pdi shows 10.92afr21.87psi shows 11.32 afr
Old Sep 5, 2012 | 01:23 PM
problem solved
Old Sep 5, 2012 | 01:26 PM
turbohatch96y7's Avatar
Was it spark related? Or the tune?
Old Sep 5, 2012 | 02:10 PM
vtec screen full of metal
i knew it wasnt the tune or spark it did this just cruising, and track.
pulled the solonoid off and was like dammm
Old Sep 5, 2012 | 02:11 PM
<<<<<<<<<<<that idiot forgot to clean it out after i spun the bearings last time
Old Sep 5, 2012 | 02:14 PM
Old Sep 5, 2012 | 03:50 PM
xenocron's Avatar
Damn...if the problem crept up over time, how do you know this isn't new metal?
Old Sep 5, 2012 | 03:58 PM
mtber's Avatar
As Chris mentioned, that could be new...
I would pull the oil pan & oil pump apart etc...
Old Sep 5, 2012 | 04:02 PM
wantboost's Avatar
Who is Mr Robot?
yea, if the metal was there all along you would've had vtec issues from the start.
Old Sep 5, 2012 | 06:05 PM
oil pan was off yesterday no issues.
it is metal as well, but from when i spun a bearing a few months ago i didnt have the head flushed out
my tuner said it is the metal that was left in the head from not being flushed.
at WOT it isnt as prominant as it is at lower rpms
i do enjoy the feedback though
EGtoua
Engine Management and Tuning
Aug 16, 2010 05:46 AM
JDM Lyfestyle
Mar 18, 2009 08:57 AM
curtisb16
Jul 26, 2007 07:01 AM
hondaeg8
May 4, 2004 03:28 PM
