Restrictor questions
Old Aug 16, 2012 | 10:01 AM
thatcivic96's Avatar
Default Restrictor questions
I am running a -3an feed line into a vibrant feed flange, will I need to run a restrictor? If so where can I pick one up? Also running -10an drain line.
Old Aug 16, 2012 | 11:08 AM
LogicMotorsports.com's Avatar
Default Re: Restrictor questions
What turbo are you running? Whats your oil psi?
Old Aug 16, 2012 | 11:14 AM
Emusa turbo. Brad new rebuilt it also. T3/t4. Car is still in build process.
Old Aug 16, 2012 | 11:27 AM
TheShodan's Avatar
Moderator
God only knows..
Old Aug 16, 2012 | 11:59 AM
Originally Posted by TheShodan
God only knows..
Is this really honestly necessary? If you don't have any sort of answer for me regarding my question why post here. Waste of mine and your time. I don't understand why people feel the need to troll.
Old Aug 16, 2012 | 12:12 PM
rich7777's Avatar
The only person that actually knows what size restrictor is needed on that heap of **** is god. So get on your knees and start asking or hope some other dipstick that's running one comes along...
It's all this cheap eGay crap that's wrecking the scene...
Old Aug 16, 2012 | 12:37 PM
I've read if you actually rebuild them that they aren't too bad. This was given to me new from my brother and not all of us have $1000 to spend on a turbo. I'm in the process of saving up for a better one. This is the one I have to run right now. I've taken it apart and rebuilt it. I've fully built my motor and everything. Thanks for all the help you guys have been! If you've got a gt35r or precision you would like to give me go for it. If not I've got this rebuilt Emusa to run. Hey at least it's balanced!
Old Aug 16, 2012 | 12:45 PM
TheShodan's Avatar
Moderator
Well, if its at least balanced, then it must be good right?
Listen. Only General oil pressure ranges at the oil feed line are going to determine what size restrictor is needed (if one is needed.) You have to ask another EMUSA owner with a similar engine platform what they decided to chance with. Since few, if any at all exist on this forum, again.. you may need to resort to prayer in order to find out.
Is that better? Or did you need some sort of hug...
Old Aug 16, 2012 | 12:55 PM
The purpose of making this thread was to find someone with a similar set up to get info from. The at least it's balanced was a sarcastic comment. I've never seen flaming like this on Honda-tech which is why when I have a question I generally come here. Guess I will looks else where for help. Thanks again. I'd prefer a cookie than a hug thanks.
Old Aug 16, 2012 | 01:13 PM
rich7777's Avatar
It happens all the time, and 9/10 it's about eBay crap. You eBay lot need to start your own forum. You could call it "Honda-Wreck.com" . That way when we start threads on your forum you can attack us haha. Search through the threads on page 1 and you'll see for your self.
j0keefe21
Aug 1, 2009 11:15 AM
93egallmotor
Jan 27, 2008 05:20 PM
sohczcturbo
Feb 10, 2007 08:54 AM
Boostage
Sep 12, 2006 03:39 PM
SIReg9
Sep 16, 2003 07:08 PM
