compression test #'s..what to expect..
Old Aug 17, 2012 | 09:49 AM
Freshdot's Avatar
Default compression test #'s..what to expect..
Going to run a compression test on my D16z6 today with JE 9:1's and Scat Rods(stock length) was wondering what would be considered good numbers to see being that I can't go off stock specs.
or, should I just be looking for consistency here??
Old Aug 17, 2012 | 09:59 AM
kbouchard1092's Avatar
Default Re: compression test #'s..what to expect..
im about 175 across the board at 8.8:1 so i would say 175-185 tops
Old Aug 17, 2012 | 10:29 AM
sleepencivic's Avatar
Make sure you do the test on a warm engine with all the plugs out, injectors unpluged and full throttle. Count the revolutions to keep it consistent for all cylinders
Old Aug 17, 2012 | 10:34 AM
i usually do it on the fourth compression stroke and take that # for every cylinder....Good info tho above!
Old Aug 17, 2012 | 01:00 PM
Freshdot's Avatar
usually when i do this I unplug my dizzy and the butt connector for the injectors, without being at full throttle...amirite??
Old Aug 17, 2012 | 01:08 PM
blackeg's Avatar
you want the throttle plate open. i usually do 6 cranks of the engine.
at 9:1 id bet you will be around 180psi. anything consistent and over 170 or so should be good
76 camaro car
Apr 20, 2017 04:47 AM
Ender Ho
Dec 24, 2014 07:15 PM
GODSPEED33
Dec 22, 2006 06:04 AM
97grnrs
Jul 22, 2006 07:52 PM
Mr.Death
Jun 14, 2004 05:18 PM
