Precision 5831 vs Precision 5431
Old Aug 20, 2012 | 07:50 PM
sparda2024's Avatar
Default Precision 5831 vs Precision 5431
SO....I have an issue...my built b16a2 needs a new turbo, but I was wanting to make sure it will still be pretty responsive and make 300-400WHP It currently has a turbonetics t3/t04e on it but its gone bad. Would the spool time and responsiveness be noticeable at all between these two turbos? I know both of them will work with how much power I want but if the responsiveness is negligible then why not get the bigger one so I can get more power out of it if I want it.
Old Aug 20, 2012 | 11:02 PM
MadVTI's Avatar
Default Re: Precision 5831 vs Precision 5431
Id go for the 5431, you could get into surge with the 5831 at certain boost levels if I'm thinking right about this. Both will be super responsive.
Old Aug 21, 2012 | 06:38 AM
sparda2024's Avatar
Do you have any idea at what psi the surge would happen? It'll be at 12psi running off the wastegate spring until i get a boost controller but I doubt i'll push it over 18psi.
Old Aug 21, 2012 | 06:47 AM
TheShodan's Avatar
Moderator
Not until about 26-28psi of boost pressure for either one. For such low boost pressure, you're fine.
Old Aug 22, 2012 | 12:16 PM
MadVTI's Avatar
Ah cool, like shodan said, should be fine with a low blow
ls1goat
Dec 2, 2013 07:53 AM
MatthewMenze
Oct 23, 2013 09:06 PM
KevinEF7
Oct 7, 2013 10:43 PM
b18cEF9
Jul 31, 2005 10:56 AM
Mr. Softee
Jul 8, 2002 06:54 AM
