high boost sputtering
Old Sep 19, 2012 | 10:08 PM
rfelix89's Avatar
Default high boost sputtering
im having issues with my car sputtutring bad on high boost. my 2nd gear is set up to 14psi car runs fins. then when i throw it into 3rd my boost is set up at 24 psi thats when the car starts sputtering bad. same goes with my 4th. 1st and second are fine. the only thing i did to the car was change my FPR i had and got tuned using an AEM with a base fuel pressure of 45psi. i swapped my rail and also installed an aeromotive i had laying around...would the 1:1 lb of pressure per lb of boost affect/ throw off my high boost tuning. im running ngk 8s gapped at .15
Old Sep 20, 2012 | 10:15 AM
Muckman's Avatar
Moderator in Chief
Default Re: high boost sputtering
Are you saying you were previously tuned up to 24psi and it drove fine, but now it wont after you swapped fuel rail and FPR? Are you monitoring AFRs? You need to verify the AFR before you melt your engine.
Old Sep 20, 2012 | 11:59 AM
Turbo-LS's Avatar
Several possibilities. Number one is stock ignition giving out. Spark blow out or leaning out. Varify your af ratios
Old Sep 20, 2012 | 12:52 PM
rfelix89's Avatar
would running c16 cause my o2 from my wideband to not read correctly? cuz after i started running the racefuel my widebamd just stays at like 14.2 reguardless of how im driving it
Old Sep 20, 2012 | 01:03 PM
TheShodan's Avatar
Moderator
No. (This is why I hate wideband gauges, as in many cases, it points people in the wrong direction, when there are other symptoms to look at0
Sounds like spark to me. Ignition system blowing out by not being able to create clean combustion at higher boost levels.
Old Sep 20, 2012 | 01:09 PM
rfelix89's Avatar
my ignition system consist of a MSD 6a box with a coil blasters ss coil and some ngk wires ngk 8 plugs gapped at .15. what would create a not clean combustion at high boost?
Old Sep 20, 2012 | 01:10 PM
rfelix89's Avatar
and thank you guys for the replies its helping look at diffrent things and helping learn more from situations like this
Old Sep 20, 2012 | 01:25 PM
TheShodan's Avatar
Moderator
gapped at .15? My goodness that's not good. That may mean the MSD box might be failing or coil not doing its job. The older analog stuff is dying out.
Old Sep 20, 2012 | 01:33 PM
rfelix89's Avatar
thats what my tuner had recommended. what do you think would be an affordable upgrade?
Old Sep 20, 2012 | 03:09 PM
TheShodan's Avatar
Moderator
Mallory Digital 6A (Or summit Racing) with an ignitor bypass (see Turbo-LS for that) and a nice gel-based coil like a MSD 8207, not those old Blaster SS Tear-gas canisters that we used to use. Those aren't made to last forever.
Old Sep 20, 2012 | 04:24 PM
rfelix89's Avatar
i read somewhere about some one having a similiar issue as me and he bypassed the ignitor and he never had that issues again.. does that sound legit?
Old Sep 20, 2012 | 04:36 PM
TheShodan's Avatar
Moderator
You must not be reading... There is an ignitor bypass, but with what you have, and other equipment you'll still have problems.
This is more of a blanket approach, not a cheap way out...
Or, change distributors that have a new ignitor in it and see what happens.
Old Sep 20, 2012 | 11:43 PM
rfelix89's Avatar
ok i decided to upgrade to the ignitor bypass summit racing digital cdi and a crane ps92 coil and new cap n rotor and new wires. hopefully this gets rid of my high boost issues. thanks gor your help shodan
rfelix89
Sep 20, 2012 12:53 PM
umair
Oct 17, 2011 08:48 AM
Andrew 825SM
Sep 22, 2002 01:26 AM
squeaky
May 14, 2002 07:07 PM
