B series block questions.
Old Sep 8, 2012 | 07:32 PM
Ghunt521's Avatar
Default B series block questions.
Wondering whats the best block to go with sleeved to 84mm and gt28r turbo. Jdm GSR or LS?
Looking for witch one will hold about 350whp with no worries. Help be great thx guys.
Old Sep 8, 2012 | 07:48 PM
phaphon's Avatar
Default Re: B series block questions.
any of those blocks will hold up 350 whp if done right
Old Sep 8, 2012 | 07:51 PM
golf-mk3's Avatar
for that power level you can use a stock block all day
Old Sep 8, 2012 | 07:54 PM
Ghunt521's Avatar
Well i was going to go with b18b block gsr head. Im think those will hold 350whp on about 12lbs
Old Sep 8, 2012 | 08:02 PM
wantboost's Avatar
Who is Mr Robot?
you'll need pistons and rods for that power... no point in sleeving, especially on a gt28r.
Old Sep 8, 2012 | 08:04 PM
Ghunt521's Avatar
Well what it I wanna go bigger turbo in the future? sleeving to 84mm would insure that everything will hold up at 400-500whp if im lucky.
Old Sep 8, 2012 | 08:15 PM
wantboost's Avatar
Who is Mr Robot?
people make 500 on stock sleeves all day long
Old Sep 8, 2012 | 08:34 PM
phaphon's Avatar
if you will want to go bigger build it the correct way the first time. get a turbo with room to grow. and you dont need 84 mm to get 350 whp you can sleeve it with a 81 mm bore gives you room for mistakes.
Old Sep 8, 2012 | 08:47 PM
Ghunt521's Avatar
b18b1 block 84mm bore Darton Sleeves
Stock LS Crank
Eagle H beam rods
Arias 9:5:1 Pistons
Cosmetic Head Gasket
Arp Head Studs
Gsr Head 3 angle valve job and port and polish
b16b cams
Garret 35r
jg intake mani
this is what im thinkin so far
Old Sep 8, 2012 | 08:48 PM
wantboost's Avatar
Who is Mr Robot?
your first post said 28r
make up your mind
Old Sep 8, 2012 | 08:51 PM
phaphon's Avatar
sounds better you still need fuel system, clutch, and i maybe forgetting some stuff i think 300-350 is a good goal learn how to drive that car. then work on traction such as tires, lsd, and traction bar.
Old Sep 8, 2012 | 08:54 PM
wantboost's Avatar
Who is Mr Robot?
also skip the b16 cams, pick up a set of gsr cams... the poor mans type r cam
and are you planning on making more power? if not, a 35r is overkill
Old Sep 8, 2012 | 09:01 PM
Ghunt521's Avatar
okay it between 35r and 28r. I was thinking GSR cams as well. Good point on the over kill for 35r. Not to sure this is my first turbo build so... just trying get everything on point.
Aem fuel Rail/FPR
Rc 550
Walboro 255
Not sure witch clutch imma go with yet. Any advice for 350-450whp?
Old Sep 8, 2012 | 09:14 PM
wantboost's Avatar
Who is Mr Robot?
competition clutch stage 5 has never steered me wrong
but you won't make 450 on a gt28r... and theres a big gap between the 2
figure out exactly what you want to do then decide on a turbo
Old Sep 8, 2012 | 09:20 PM
phaphon's Avatar
theres a set of 725 id forsale in the market place. only 300 bucks pick it up they will be alot better then rc's .
Old Sep 8, 2012 | 09:35 PM
Ghunt521's Avatar
I have 550's brand new already...lol
Imma go with 28r
Old Sep 8, 2012 | 09:43 PM
phaphon's Avatar
good luck with your build ! have fun take your time.
Old Sep 8, 2012 | 09:56 PM
wantboost's Avatar
Who is Mr Robot?
still don't need sleeves, especially for a build centered around a gt28r
Old Sep 9, 2012 | 05:17 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
There is so much wrong information in this thread from almost every poster... I don't even know where to begin.
Old Sep 10, 2012 | 11:59 AM
Golden Eagle's Avatar
pm sent
thugsbryan
Mar 27, 2015 09:48 AM
spindler1
May 10, 2009 10:02 PM
beyondstock
May 8, 2009 07:04 PM
Hondatuner88
Oct 4, 2006 08:54 PM
Rhetoric
Oct 10, 2001 07:38 AM
