boost problem need help
Old Aug 15, 2005 | 06:40 PM
evilk's Avatar
Default boost problem need help
i just put in my turbo kit and tha tial 38 mm waste gate has a 7 lb spring in there and i put a turbo xs boost controller in there and i close it all tha way because i don;t want it to go pass 7lb yet and when i rev it to 6500 rpm its jump to 10 or 12 lb on stocck b16 bottom wat should i do to get it to stay at 7lb or 10lb
Old Aug 15, 2005 | 07:09 PM
Jwbetley's Avatar
Default Re: boost problem need help (evilk)
um... if you have a 7 psi spring, it should not go past 7 psi. Check your wastegate vaccum. And make sure that you actually out the vaccum hose in the right valve and not the vant valve for the boost controller.
Old Aug 17, 2005 | 07:15 PM
evilk's Avatar
Default Re: boost problem need help (Jwbetley)
i dunno man but it still goes up
Old Aug 17, 2005 | 07:27 PM
BenzTek134's Avatar
if its a 7psi spring u might have your gauge connected to a wrong vacuum source dick around with it and try afew different vacuum lines see what happens
Old Aug 17, 2005 | 08:28 PM
Jwbetley's Avatar
Default Re: boost problem need help (BenzTek134)
better yet, make it simple for yourself. Run your wastgate, bov, and boost gauge off of your brake booster if you have not already. Just takes three t fittings and a dozen hose clamps.
Old Aug 17, 2005 | 09:19 PM
SFWD 1934's Avatar
Make sure that you did not get a .7 bar, that is a 10 PSI spring. If it is a big yellow, than that is what you got.
Jason
Old Aug 17, 2005 | 09:34 PM
SOHC_MShue's Avatar
you may be getting boost creep depending on where your wastegate is located on the manifold.
Old Aug 18, 2005 | 04:27 AM
delslo93's Avatar
Default Re: boost problem need help (SOHC_MShue)
Make sure that the vaccum/boost lines going to and from the boost controller are the right ones going in the correct direction. I've read that if you mix these two up, the boost will go to whatever. You need it going the right direction for it to work properly. You want the line to go from the compressor side of the turbo to the bottom of the controller, and the other line going from the connection on the side of the controller to the wastegate. Just an idea to double check
Old Aug 21, 2005 | 06:23 PM
evilk's Avatar
Default Re: boost problem need help (delslo93)
thanx for tha tips guys
b20beast83
Jan 30, 2010 04:49 PM
Makdaddynuge
Jun 4, 2006 03:46 PM
SOHC_MShue
Mar 14, 2005 03:00 PM
kaj
May 20, 2003 03:32 PM
SlowB16
Apr 17, 2002 08:49 AM
