INSTALL: ARP Extended studs; How to?
Old Aug 17, 2005 | 01:54 AM
jDMJeRk's Avatar
Default INSTALL: ARP Extended studs; How to?
Originally posted on g2ic.com
With BOTI right around the corner and hopefully my goal of 400whp in the DA, Im forced to get extended lugs to run slicks... With that said has anyone installed these on a G2?
Few of my friends have done EG's but Im wondering how much different they are.
I searched (rather on g2ic.com; not ht) but I found alot of arguements about what was better rather then how the install process went; other then welding them in?
Tips, links, NO arguements , would be really appreciated!
-n!ck
Old Aug 17, 2005 | 05:37 AM
Fred n J_v2.0's Avatar
Default Re: INSTALL: ARP Extended studs; How to? (jDMJeRk)
Here you go, process should be no different:
https://honda-tech.com/zerothread?id=907985
Old Aug 17, 2005 | 08:56 AM
DaveF's Avatar
Default Re: INSTALL: ARP Extended studs; How to? (Fred n J's_1.8's)
thats an awsome write up, i never knew how the hubs came off. but i learned something today
Old Aug 17, 2005 | 09:57 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: INSTALL: ARP Extended studs; How to? (Dturbocivic)
we did it on my buddies car. a slide hammer works wonders but if you are scrawny white guys like me, it could take awhile lol. just make sure that the studs are seated fully before you go to try and put the hub back on
Old Aug 17, 2005 | 05:23 PM
jDMJeRk's Avatar
Default Re: INSTALL: ARP Extended studs; How to? (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">we did it on my buddies car. a slide hammer works wonders but if you are scrawny white guys like me, it could take awhile lol. just make sure that the studs are seated fully before you go to try and put the hub back on</TD></TR></TABLE>
This was the same method I was told to try... Thanks!
Thanks Earl for moving my thread
-n!ck
noridetoolow
Jun 12, 2011 06:40 PM
Quickridez_3
Sep 30, 2008 04:08 PM
Flux
Dec 27, 2006 01:33 PM
EK k kay
Mar 16, 2006 10:51 PM
bigBOI_92DA9
Aug 19, 2005 08:33 AM
