What oil to run?
Old Aug 16, 2005 | 08:45 PM
Honduh Chicken's Avatar
I fry gay turkeys
Default What oil to run?
Boosted B18c1
t3/t4 14 psi.
So which oil should I use I've been told everything from 5w50 to 20w50. It's a turbo car, so I just want to make sure I have the right oil in the bitch.
TYIA.
Old Aug 16, 2005 | 11:18 PM
whoneedzvtec's Avatar
Default Re: What oil to run? (Honduh Chicken)
i run 15w50 mobil 1 in mine during the hot part of the the summer and in the cooler months and the winter i use 10w30.
Old Aug 17, 2005 | 01:52 AM
eazycivic's Avatar
Default Re: What oil to run? (dc2ls-t)
20/50 Valvoline VR1
Old Aug 17, 2005 | 01:57 AM
Junk Ex's Avatar
Default Re: What oil to run? (eazycivic)
castrol gtx 10-30
Old Aug 17, 2005 | 04:18 AM
tthame1's Avatar
Default Re: What oil to run? (Junk Ex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Junk Ex &raquo;</TD></TR><TR><TD CLASS="quote">castrol gtx 10-30 </TD></TR></TABLE>
Old Aug 17, 2005 | 06:56 AM
11psiTurboSI's Avatar
Default Re: What oil to run? (tthame1)
10w-30
Old Aug 17, 2005 | 07:22 AM
turbosi03's Avatar
Mobil 1 10w-30
Old Aug 17, 2005 | 07:25 AM
MR.M's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2ls-t &raquo;</TD></TR><TR><TD CLASS="quote">i run 15w50 mobil .</TD></TR></TABLE>
Old Aug 17, 2005 | 11:25 AM
notoriousB's Avatar
those of you running 10w30, may I ask why?
I'm guessing your cars were 5w30 from the factory, why increase the cold start viscosity but keep the hot viscosity the same? Just curious, not knocking anyone.
I used to run 5w30 but now on my built motor I've stepped up to 10w40.
Old Aug 17, 2005 | 06:26 PM
Bror Jace's Avatar
Default Re: (notoriousB)
10W-30 tends to be a bit more stable and will hold its grade longer. So, if you don't need thestart the engine in sub-freezing weather, you might want to consider a 10W-30 over a 5W-30.
Old Aug 17, 2005 | 07:29 PM
BigMoose's Avatar
Default Re: (Bror Jace)
The wider the range, the less heat stability the oil has for a given type (dyno/syn). That is it will start to go thin sooner.
Old Aug 17, 2005 | 09:16 PM
SFWD 1934's Avatar
Default Re: (BigMoose)
I used Red Line Oil 10W-30 for so long. New set up, I have been running the Havoline Racing Revolution 10W-30. That seems to be a really good oil. Liking it a lot.
Jason
Old Aug 17, 2005 | 09:19 PM
beerbongskickass's Avatar
s2k5
Honda S2000
21
Sep 22, 2007 08:44 PM
iheartintegras
Apr 16, 2007 11:53 AM
TurboEG6
38
Aug 31, 2006 07:55 PM
atmosphere
Sep 23, 2005 06:53 PM
mportbusta
Mar 13, 2005 11:56 PM
