need ecu help quick
Old Aug 17, 2005 | 04:31 PM
bayoufrogg's Avatar
Default need ecu help quick
Im about to purchase a p06 for hondata in my 92 prelude manual trans. It says it came out of a OBD1 ECU from a 95 HONDA CIVIC DX with 5 Speed Manual Transmission. the part number is 37820-P06-C02 . Both my ecu(the p13) and the p06 are non-vtec OBD1 ecus......so im thinking this will be okay right? The p06 was number three in the order of preference for my car on hondatas website. Is there anything else that i need to match up?
Old Aug 17, 2005 | 04:34 PM
bayoufrogg's Avatar
just found another one, but the ecu number is
37820-P06-A02. Whats the difference? Is either one fine? And does it matter that the p06 is for SOHC when my h23 is DOHC or does hondata overide all the stock information?
Old Aug 18, 2005 | 06:21 AM
bayoufrogg's Avatar
bump
Old Aug 19, 2005 | 12:19 PM
bayoufrogg's Avatar
im sure SOMEONES got to know which one i should get
Old Aug 19, 2005 | 12:39 PM
BlackCRX's Avatar
it will be fine given you still have stock injectors and not larger sized ones
you can also get those non vtec ecu;s converted to vtec for a small fee
Old Aug 19, 2005 | 12:40 PM
flip1199's Avatar
Default Re: (bayoufrogg)
dont matter what ecu it is. just at long as it's a obd1 5speed ecu. i used a pr4 in my setup with no problems.
Old Aug 21, 2005 | 08:20 AM
bayoufrogg's Avatar
Well.....I dont have stock injectors. I ve got 1000cc precisions. What difference does that make?
I wouldnt need VTEC, just the opposite. I would be getting a VTEC computer for a NONVTEC car. Is there any modification needed for this? I would like to get the pr4 or p06 since they are cheaper, but i need to make sure everything will work out. thanks.
Old Aug 21, 2005 | 08:29 AM
wantboost's Avatar
Who is Mr Robot?
he thinks you arent going to chip it. you cant run 1000cc injectors on a stock ecu, you need hondata crome or uberdata
Old Aug 21, 2005 | 09:58 AM
flip1199's Avatar
Default Re: (wantboost)
ok well let me clearify myself. i had a pr4 with my hondata setup that worked fine with the 1000cc injectors i was running.
rmiller
Feb 1, 2008 10:10 PM
NuclearB18B
Sep 19, 2003 04:15 PM
phil2000
Jul 10, 2003 07:49 AM
yellowbuffalo
Jun 4, 2003 06:44 PM
