Oil Line question???
Old Aug 15, 2005 | 04:51 PM
StolenTeg's Avatar
Default Oil Line question???
My oil line have a tiny leak and im wondering if it okay to use that? would the oil pressure go down a lot?
Old Aug 15, 2005 | 05:06 PM
95GSRT's Avatar
you'd probably be better off fixing that.
Old Aug 15, 2005 | 05:12 PM
StolenTeg's Avatar
Default Re: (95GSRT)
i plug one end and blow through it, air escape VERY slowly and i dont think that the oil would leak but im worry about lossing oil pressure.
Old Aug 15, 2005 | 05:40 PM
nota-eg's Avatar
Default Re: (StolenTeg)
Is it your feed or your return line? Return line I wouldn't worry too much about, but the oil feed is under around 50-70 psi of pressure (I think) That pressure adds up and will cause you to lose a lot of oil and will eventually widen that hole.
Old Aug 15, 2005 | 06:06 PM
StolenTeg's Avatar
Default Re: (nota-eg)
it not a hole, it a thread hole where i srew a bolt in but it leak very little for some reason...
cdog19
Feb 9, 2004 01:15 PM
crx1856
Sep 19, 2003 09:11 AM
turbotec
Feb 26, 2002 12:36 PM
LudeSi-93
Sep 21, 2001 09:50 AM
