blew headgasket (vid inside)
Old Aug 18, 2005 | 01:08 PM
B18 CYA's Avatar
Default blew headgasket (vid inside)
well went to tune on the dyno yesterday. numbers seem kinda shitty ...made 334whp and 242 ft lbs torque at 20 psi on a T3/t04e ... 2.5" exhaust.... but on the last run the headgasket blew at 7800 rpms and one of the coolant hoses burst as a result of the headgasket. anywho, the strange part was that right when this happened, the passenger side wheel stopped dead and the roller under the wheel was still rolling which kinda ate up my tire in a flat spot as it rolled against the tire. thats just the strange part which we dont understand. spark plugs were fine but 1st one was wet because of the coolant in the cylinders. anyone have any input as what may have caused it? head lifting? the car still turns over ns hit...had arp head studs and were torqued to 100ft lbs. was thinking to get a new oem headgasket and torque to 110? heres the vid:
http://videos.streetfire.net/P...3A529
Old Aug 18, 2005 | 01:13 PM
DRAGLS's Avatar
Default Re: blew headgasket (B18 CYA)
I don't have an answer to your post, but why are you torquing the head studs to 100ft/lb? At that much torque you probably pull the threads out on that cylinder.
Old Aug 18, 2005 | 01:14 PM
B18 CYA's Avatar
no the head was torqued onto the studs at 100 ft lbs
Old Aug 18, 2005 | 01:16 PM
ProjectDarkBlack's Avatar
Default Re: (B18 CYA)
... isn`t it supposed to be 69 ft. lbs or something?
Old Aug 18, 2005 | 01:17 PM
DRAGLS's Avatar
I understand that I use them on my tt supra and turbo integra and 100ft/lbs is way to much. 80ft/lbs tops
Old Aug 18, 2005 | 01:20 PM
B18 CYA's Avatar
do u think that is what may have caused it?
Old Aug 18, 2005 | 01:26 PM
DRAGLS's Avatar
If the threads got pulled out then yes that is your problem.
Old Aug 18, 2005 | 02:46 PM
B18 CYA's Avatar
bump
Old Aug 18, 2005 | 02:53 PM
SpdFrk's Avatar
Damn, that sucks bro.
Modified by SpdFrk at 8:40 PM 8/18/2005
Old Aug 18, 2005 | 05:29 PM
99blusi's Avatar
Default Re: (SpdFrk)
61ft lbs for a b16...torqued in a 2 step sequence...
Old Aug 18, 2005 | 06:17 PM
mike93eh
Guest
Posts: n/a
Default Re: (99blusi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blusi &raquo;</TD></TR><TR><TD CLASS="quote">61ft lbs for a b16...torqued in a 2 step sequence...</TD></TR></TABLE>
yup! 100 ft lbs??!?? DAMN
your hose burst because the boost escaped thru the headgasket and went into the coolant.
get a honda oem hg and use lots of copper spray on it and torque the arp's to 60-65 ft lbs. in a 2 step fashion.
Old Aug 18, 2005 | 06:26 PM
B18C1CYA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18 CYA &raquo;</TD></TR><TR><TD CLASS="quote">no the head was torqued onto the studs at 100 ft lbs</TD></TR></TABLE>
that is to high , read the pink paper that comes with the studs , 70ftlbs with molly lube and 85ftlbs with 30w oil , you can warp the head if you torque them to much ,
Old Aug 18, 2005 | 06:29 PM
Adi Radoncic's Avatar
On Fire!
Default Re: (mike93eh)
God Damn that **** was violent!!
Did you replace the head gasket at the time when you did the arp studs?
You should only have torqued the head to 80ftlb with arp moly to begin with, did you have a boost spike at all when the gasket let go?
Old Aug 18, 2005 | 06:47 PM
reactiondc2's Avatar
Default Re: (Adi Raaa)
the last time i saw a hg blow on the dyno was cause the sleeves cracked but anyway if i was you i would buy a new gasket get the head checked for warpage and torque the studs correctly
Old Aug 18, 2005 | 06:53 PM
ladysman's Avatar
Default Re: (reactiondc2)
The studs are useless too now. You need a new set as they have been overstretched.
Old Aug 18, 2005 | 07:05 PM
B18C1CYA's Avatar
Default Re: (ladysman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman &raquo;</TD></TR><TR><TD CLASS="quote">The studs are useless too now. You need a new set as they have been overstretched.</TD></TR></TABLE>
Old Aug 19, 2005 | 07:25 AM
B18 CYA's Avatar
how do i check if the head is warped or arp head studs are stretched?
Old Aug 19, 2005 | 07:51 AM
93si-hybrid's Avatar
Damn that sucks!
Old Aug 19, 2005 | 08:32 AM
vaporboy12's Avatar
Default Re: (93si-hybrid)
get new stud and take the head to a machine shop to check to see if it warped
Old Aug 19, 2005 | 08:48 AM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18 CYA &raquo;</TD></TR><TR><TD CLASS="quote">how do i check if the head is warped or arp head studs are stretched?</TD></TR></TABLE>
Use a precision straight edge and some feeler gauges to check for warpage. A helms manual will tell you how.
Old Aug 19, 2005 | 08:58 AM
tuoniz's Avatar
Ouch $$$$
Old Aug 19, 2005 | 10:48 AM
Smokinsax's Avatar
The Boot
damn man...that was a crazy vid.
Old Aug 19, 2005 | 10:52 AM
Muckman's Avatar
Moderator in Chief
What possesed you to torque them to 100? Do you think more is better or something?
Old Aug 20, 2005 | 08:07 AM
ladysman's Avatar
I can tell you they are stretched. Call ARP too and tell them what you torqued them at...
Old Aug 20, 2005 | 10:13 AM
G
sh!t happens.
I can tell you they are stretched. Call ARP too and tell them what you torqued them at... </TD></TR></TABLE>
Yea, damn 100ft is alot...
