Oil dipstick melted... Any suggestions?
Old 08-18-2005, 06:09 PM
mike93eh
Guest
Posts: n/a
Default Oil dipstick melted... Any suggestions?
my oil dipstick has completely melted and it is unusable now. is there any kind of aftermarket one that would hold up better to the heat from the turbo? i already tried bending the dipstick tube back away from the manifold. its also melting my fan wires. is this **** suppose to be THAT hot?
any suggestions?
Old 08-18-2005, 06:24 PM
ginoboy1978's Avatar
Default Re: Oil dipstick melted... Any suggestions? (mike93eh)
Damn thats one hot mani......i've never heard of one melting wires and an oil dipstick.
Whats your egt read while cruising on the highway?
DAN
Old 08-18-2005, 07:09 PM
mike93eh
Guest
Posts: n/a
Default Re: Oil dipstick melted... Any suggestions? (ginoboy1978)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ginoboy1978 &raquo;</TD></TR><TR><TD CLASS="quote">Damn thats one hot mani......i've never heard of one melting wires and an oil dipstick.
DAN</TD></TR></TABLE>
dont know, dont have a egt gauge. so youre saying its abnormaly hot?
right now im on th 5psi with the greddy z6 kit. it does get hotter than hell. i heard that the emanage map that comes pretuned with the kit runs on the rich side. would that make it hotter? dont have a wideband yet either..
Old 08-18-2005, 07:47 PM
nota-eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh &raquo;</TD></TR><TR><TD CLASS="quote">dont know, dont have a egt gauge. so youre saying its abnormaly hot?
right now im on th 5psi with the greddy z6 kit. it does get hotter than hell. i heard that the emanage map that comes pretuned with the kit runs on the rich side. would that make it hotter? dont have a wideband yet either..</TD></TR></TABLE>
Running lean will make it run hotter.
Mabe you should look into some of that turbo coating stuff they have to keep heat inside the manifolds/turbos. Not the heatwrap, but the actual coating they put on the inside and outside of turbos to help them disapate/contain heat.
Old 08-18-2005, 07:49 PM
PrecisionH23a's Avatar
Default Re: Oil dipstick melted... Any suggestions? (nota-eg)
This one that im selling on ebay.
http://cgi.ebay.com/ebaymotors...%3AIT
Old 08-18-2005, 07:51 PM
mike93eh
Guest
Posts: n/a
Default Re: Oil dipstick melted... Any suggestions? (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">This one that im selling on ebay.
http://cgi.ebay.com/ebaymotors...%3AIT</TD></TR></TABLE>
i seen that but they sell for $19.99 brand new
Old 08-18-2005, 07:52 PM
Not the OG STR one though.
Old 08-18-2005, 07:57 PM
mike93eh
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">Not the OG STR one though.</TD></TR></TABLE>
didnt know they had more than one style?
Old 08-19-2005, 08:28 AM
epic1si's Avatar
I use a Lokar oil dipstick. it get's really effin hot though so don't try to check your oil after you've been driving hahaha.
Old 08-19-2005, 09:09 AM
tuoniz's Avatar
Whatever you do get a stock dipstick dont get an aftermarket. Sometimes not accurate length.
Old 08-19-2005, 09:14 AM
mike93eh
Guest
Posts: n/a
Default Re: (tuoniz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuoniz &raquo;</TD></TR><TR><TD CLASS="quote">Whatever you do get a stock dipstick dont get an aftermarket. Sometimes not accurate length.</TD></TR></TABLE>
well i would check to make sure it is acurate with my stock one first before i use it.
Old 08-19-2005, 09:26 AM
i my honda
Global Mod
White Smoke's Avatar
Its normal. I see them melt all the time.
I have the STR unit and it works great. Don’t just buy another stock unit! It will just melt again. You need an all-metal one. Just check the level with the stock stick and then put in the aftermarket one. Most aftermarket units are not the right length but Im sure you could figure it out.
Old 08-19-2005, 11:25 AM
mike1114's Avatar
Default Re: Oil dipstick melted... Any suggestions? (White Smoke)
Even with a full race mani, I bent my stocker so it wouldn't melt.
It has cracks and **** in it from getting real hot but it did that at first and now, after months of driving, it hasn't changed.
Still can't pull that ****** out when its hot though!!!
Old 08-19-2005, 02:41 PM
mike93eh
Guest
Posts: n/a
im not just talking about the handle part that melted. the rubber part that seals the hole has melted and its useless now. i dont get it either. the rubber hoses for my mbc are right next to the mani and turbo and they are fine. the dipstick is below the mani...
Old 08-19-2005, 05:01 PM
epic1si's Avatar
before i got my lokar dipstick i used to just go to the junkyard and grab a handful of dipsticks. the rubber always melts/cracks.
Old 08-20-2005, 07:43 AM
T3T495GSR's Avatar
Default Re: (epic1si)
im on my 5th dipstick needing a new one now too. what is this str one everyone is talking about?
Old 08-22-2005, 06:41 AM
tuoniz's Avatar
Default Re: (mike93eh)
well i would check to make sure it is acurate with my stock one first before i use it.</TD></TR></TABLE>
just saying if you order it offline have had trouble in the past
Old 08-22-2005, 08:51 AM
beepy's Avatar
All else fails stick one of those spark plug boot heat shields on the dipstick.
jamison1486
08-23-2007 05:31 PM
JLHDOHC
03-01-2006 06:29 AM
roydogg
11-17-2003 08:33 PM
Muckman
10-07-2003 01:16 PM
Snafu-Si
02-10-2002 09:43 AM
Quick Reply: Oil dipstick melted... Any suggestions?
