Difference between 40mm and 44mm wastegate?
Old Aug 18, 2005 | 09:07 PM
2LiterTurboSeR's Avatar
Default Difference between 40mm and 44mm wastegate?
I'm in the process of talking to a company about making a manifold, and we were discussing fitment issues between the firewall and the manifold on my next project. I'm using a T04S (.60/.70) on a 2.4 liter engine, non Honda. Shooting for 400-500 whp.
Which wastegate would be more appropriate and why? The engine itself will be revving to 7k rpms, running somewhere around 20 psi. I just want to run the best setup possible without going overkill. I am partial to the 44mm, I just don't know why.
Any help is appreciated.
Old Aug 19, 2005 | 03:04 AM
PM-Performance's Avatar
Default Re: Difference between 40mm and 44mm wastegate? (2LiterTurboSeR)
For lower boost bigger is supposedly better. For higher boost smaller is supposedly better.
40's arent produced any more. They were discontinued like a year and 1/2 ago. But you can still get them.
44mm is all vbanded which is nice.
Either one you cant go wrong really
Old Aug 19, 2005 | 11:38 PM
Boostfed's Avatar
New User
I do have a 40mm Tial for sale if interested, just throwing it out there But the Bigger 44mm Tial is preferable and it is VBand makes it simple and if you have to rotate it to clear things for your dumptube or what not it is nice. Also check out http://www.tialsport.com Technical section gives the dimensions of each of their wastegates too sir. Good luck.
Go to Website click on Technical and then here
"Waste Gate Size Diagram
Diagrams show part dimension information for waste gates.
38 mm • 40 mm • 44 mm • 46 mm"
SAMCRO08
Oct 17, 2013 11:43 AM
90Rexx
Dec 8, 2009 03:42 PM
60-1
Mar 18, 2004 11:30 PM
60-1
Jan 31, 2004 05:41 PM
BlackGSR
Apr 16, 2002 07:44 AM
