head gasket problem
Old Aug 15, 2005 | 09:36 PM
s2kdre's Avatar
Default head gasket problem
i built my new motor using a 81.5mm bore with a stock bore headgasket, cp's eagles and a blockguard, it was tunned from the previous setup at 7psi on the afc hack, when i went to the dyno to tune with crome, when we hit 12psi the coolant overflow tank shot coolant out and there was no pressure in the system at all, so i went to buy a new cap and still no luck. I took my thermostat out, and for the first time today it started to over heat a little in traffic, so i'm gonna change the head gasket with a .20 bore and see what happens, by the way, when i hit it first gear today nothin but white smoke out the exhaust. Guys why do u think the head gasket just gave out like that? Could it be headlifting?
Old Aug 15, 2005 | 09:56 PM
SOHC_MShue's Avatar
Default Re: head gasket problem (jdmhonda)
You probably killed it running the hack with its advanced timing curve. I'm sure its probably been leaking a tiny bit for a while and you just didn't notice it.
Old Aug 16, 2005 | 07:09 AM
s2kdre's Avatar
Default Re: head gasket problem (SOHC_MShue)
ttt
Old Sep 13, 2005 | 08:16 PM
Black DC2's Avatar
ouch sound like HG problem
rajah99
Honda CR-V & Element
11
Jan 23, 2012 09:49 AM
kasperxtcy
Apr 3, 2010 11:36 PM
D3vin
14
Mar 14, 2010 08:41 PM
InTeGrA B18b1
Apr 7, 2005 04:08 PM
prendi
Aug 22, 2003 02:10 PM
