Hooking Stainless lines to bov/wastegate/boost controller...
Old Aug 16, 2005 | 10:10 AM
done's Avatar
Default Hooking Stainless lines to bov/wastegate/boost controller...
How exactly do you hook stainless/prolite lines to the boost controller? the boost controllers have plastic nipples..
Old Aug 16, 2005 | 10:19 AM
Finland's Avatar
stainless lines are rubber on the inside, so just slip it onto the nipple and clamp it.
edit: most Parker stores sell it by the foot without fittings on the ends.
Old Aug 16, 2005 | 10:22 AM
beepy's Avatar
Default Re: (Boondock Saint)
A company called Proform makes -AN simulating hose clamps. Just FYI.
Old Aug 16, 2005 | 10:41 AM
done's Avatar
Default Re: (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">A company called Proform makes -AN simulating hose clamps. Just FYI.</TD></TR></TABLE>
link
Old Aug 16, 2005 | 10:49 AM
Treblarefils's Avatar
Default Re: (Jordo@KAP)
http://www.google.com
Old Aug 16, 2005 | 11:03 AM
done's Avatar
Default Re: (Treblarefils)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Treblarefils &raquo;</TD></TR><TR><TD CLASS="quote">http://www.google.com</TD></TR></TABLE>
tryed that smart ***
future reference
http://store.summitracing.com/...00405
Old Aug 16, 2005 | 11:08 AM
tony1's Avatar
get a different solenoid with threaded inputs.
Old Aug 16, 2005 | 11:11 AM
done's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">get a different solenoid with threaded inputs.</TD></TR></TABLE>
GM perhaps?
Old Aug 16, 2005 | 11:15 AM
Dunc's Avatar
BCICAN
hahahahaha...just buy the npt to -an adapters and make the stainless line the correct way instead of the ricer half assed way. The line is really easy to construct and takes like 5 minutes.
Old Aug 16, 2005 | 11:35 AM
tony1's Avatar
Apex has a very good solenoid.
Old Aug 16, 2005 | 11:39 AM
done's Avatar
Default Re: (tony1)
Old Aug 16, 2005 | 02:47 PM
Dee's Avatar
Dee
The lines that run to and from my HKS wastegate & AVC-R solenoid are stainless steel while the line that runs from my vacuum block to the BOV is a rubber line with an AN fitting.
I'll try to post some pics later when I get home.
Modified by Dee at 7:08 PM 8/16/2005
Old Aug 16, 2005 | 03:05 PM
caspers_hatch's Avatar
I there a remedy for the profec b solenoid?
Such as using the one pictured above, i mean....can you do that? I don't know much about the solenoid and swapping them out.
I don't like the small little nipples coming out of it though, thats for sure.
Bump for some info
Old Aug 16, 2005 | 07:03 PM
Sprockets's Avatar
Default Re: Hooking Stainless lines to bov/wastegate/boost controller... (Jordo@KAP)
Why don't you just use braided teflon -an lines with NPT adapters on both ends?
edit...I guess someone already suggested that.
Old Aug 16, 2005 | 07:41 PM
ComputerJLT's Avatar
Default Re: (caspers_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by caspers_hatch &raquo;</TD></TR><TR><TD CLASS="quote">I there a remedy for the profec b solenoid?
Bump for some info </TD></TR></TABLE>
i've been doing some research and discovered something startling;
apex and greddy use the SAME solenoid; and one can find that solenoid (generic 3 way 12v pnumatic solenoid) for very cheap if they look arond.
less than a third what apex wants for it
also if you need a new solenoid look for "EBCS solenoid" on google; this (smart) company sells these solenoids for $60 and they'll work with an avc-r; profec; any single solenoid style ebc
Old Aug 16, 2005 | 07:50 PM
done's Avatar
Default Re: (ComputerJLT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComputerJLT &raquo;</TD></TR><TR><TD CLASS="quote">i've been doing some research and discovered something startling;
also if you need a new solenoid look for "EBCS solenoid" on google; this (smart) company sells these solenoids for $60 and they'll work with an avc-r; profec; any single solenoid style ebc</TD></TR></TABLE>
how exactly does the wiring work?? cut the profec plug, and rewire it?
Old Aug 16, 2005 | 07:55 PM
done's Avatar
you sir are the ******* man..
Old Aug 16, 2005 | 09:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordo@KAP &raquo;</TD></TR><TR><TD CLASS="quote">
how exactly does the wiring work?? cut the profec plug, and rewire it?</TD></TR></TABLE>
it's a 12vdc 3-way solenoid
there really isn't a way you can **** up the wiring the solenoid gets +12v and GND when it needs to be open or closed (depending on the valve side you use).
I'm probably going to make a big giant thread that will make all the big EBC sellers go when i get a few solenoids in and test 'em out with the Profec b spec 2 and my AVCR
Old Aug 16, 2005 | 09:08 PM
This is a beautiful thing!
Old Aug 17, 2005 | 06:36 AM
Dee's Avatar
Dee
Here's a pic of my old setup.
Old Aug 17, 2005 | 06:41 AM
tuoniz's Avatar
I'm going to give it a try
Old Aug 17, 2005 | 09:24 AM
done's Avatar
Default Re: (tuoniz)
anyone know the npt fitting for a tial bov and tial 44?
Old Aug 17, 2005 | 10:25 AM
civicross's Avatar
Read below he's right I was off .5
Modified by civicross at 10:50 PM 8/17/2005
Old Aug 17, 2005 | 11:47 AM
97turbols's Avatar
they're 10mm x 1.0 all part dimensions are on tial's web site: http://www.tialsport.com/
Old Aug 17, 2005 | 12:11 PM
done's Avatar
Default Re: (97turbols)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97turbols &raquo;</TD></TR><TR><TD CLASS="quote">they're 10mm x 1.0 all part dimensions are on tial's web site: http://www.tialsport.com/</TD></TR></TABLE>
thanks alot
why do you guys run -6an from the bov?? why not just -4an?
