what size injectors to run b16??
Old Aug 16, 2005 | 03:22 AM
88crxhfb16's Avatar
Default what size injectors to run b16??
what size are stock b16 injectors??? and also what is the largest size injector I can run and still maintain idle without engine managment??????
Old Aug 16, 2005 | 06:05 AM
whoneedzvtec's Avatar
Default Re: what size injectors to run b16?? (88crxhfb16)
not sure about what size stock b16 injectors are. sorry about that one. but i am pretty sure u need some kind of piggy back or something if u change injector size at all, even if u just go one size larger. if u install new injectors and u cant relay that to ur ecu there will probably be a prob with that. like i said though im not 100% on that one. i would say u need to chip ur ecu to do this. anyway good luck with ur set-up.
Old Aug 16, 2005 | 06:15 AM
Willie's Avatar
stock injectors on a b16 are 240cc
Old Aug 16, 2005 | 08:14 AM
11psiTurboSI's Avatar
Default Re: (Willie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willie &raquo;</TD></TR><TR><TD CLASS="quote">stock injectors on a b16 are 240cc</TD></TR></TABLE>
Correct!
Old Aug 16, 2005 | 02:24 PM
88crxhfb16's Avatar
bump
Old Aug 16, 2005 | 02:25 PM
88crxhfb16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crxhfb16 &raquo;</TD></TR><TR><TD CLASS="quote"> and also what is the largest size injector I can run and still maintain idle without engine managment?????? </TD></TR></TABLE>
Old Aug 16, 2005 | 03:03 PM
dumpeDc2's Avatar
I'm a Jackass
320 will idle with the stock ECU anything bigger i dont know
Old Aug 17, 2005 | 10:32 AM
BokChoy's Avatar
Default Re: what size injectors to run b16?? (dumpeDc2)
i bumped my h23 to 345's from 240's no problems, same injector sizing totally different motor... I guess I really shouldn't have posted then.... hmmm.
Old Aug 17, 2005 | 10:45 AM
Default Re: what size injectors to run b16?? (BokChoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BokChoy &raquo;</TD></TR><TR><TD CLASS="quote">i bumped my h23 to 345's from 240's no problems, same injector sizing totally different motor... I guess I really shouldn't have posted then.... hmmm.</TD></TR></TABLE>
H22's run 290cc injectors stock, I would think a H23 would run the same size as a H22???
Old Aug 17, 2005 | 11:02 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: what size injectors to run b16?? (11psiTurboSI)
yea, 310's are all the you can run and thats a very small jump from 240.... and besides ownig a turbo honda with no engine management is like ******* that street ***** without a rubber.... kinda stupid hurts you in the long run and costts more overall
00 civic si
Sep 22, 2009 08:28 PM
rippinitup01
Mar 1, 2007 04:49 PM
91crxturbo
Aug 17, 2006 03:05 AM
doublejz
Oct 28, 2003 08:57 AM
kell211
Oct 6, 2003 07:33 PM
