New internals
Old Aug 17, 2005 | 10:44 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default New internals
Would getting all new internals (pistons, rods, springs, valves, retainers) and keeping them at stock LS spec. be any different then keeping my orignal parts?
besides the fact that they all new!
would these new parts give me different hp and torque even though they are at stock spec??
thanks in advance
Old Aug 17, 2005 | 11:25 PM
mtber's Avatar
Default Re: New internals (00IntegrAllmotoR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR &raquo;</TD></TR><TR><TD CLASS="quote">Would getting all new internals (pistons, rods, springs, valves, retainers) and keeping them at stock LS spec. be any different then keeping my orignal parts?
thanks in advance</TD></TR></TABLE>
If you kept the same cam profile, compression ratio & bore etc. Your motor would theoretically be very similar except for the fact that it may output a slightly higher compression number per cylinder due to the freshly rebuilt setup.
What exactly are you trying to accomplish ?
Old Aug 18, 2005 | 01:34 AM
eazycivic's Avatar
R u using factory parts or going forged.... if the same spec the only think you would gain is you would be able to handle more power with a forged bottem end in comparrison to your stock bottem end
Old Aug 18, 2005 | 01:36 AM
JDMlyfestyle's Avatar
If you got forged internals along with a good valvetrain you can rev your motor up higher.
Old Aug 18, 2005 | 09:04 AM
HT Black OPs
Default Re: (JDMlyfestyle)
i plan on LS-T, the valve train i was looking at is as follows:
Crower 404 cams
Crower double springs
Crower TI retainers
Crower Cam gears
Crower valves
Block:
CRP pistons 8:5:1
Maybe eagle or crower rods
What i need help on is what valve spec i should get?? keep it stock spec just new valves?
And what piston spec i should get?? will forged pistons still work with the same stock bore??
Old Aug 18, 2005 | 12:41 PM
HT Black OPs
Default Re: (00IntegrAllmotoR)
bump
Old Aug 18, 2005 | 06:41 PM
HT Black OPs
anyone else?
Old Aug 18, 2005 | 06:50 PM
Sketch_hs's Avatar
what turbo are you going to run?
Old Aug 18, 2005 | 07:02 PM
HT Black OPs
Default Re: (Sketch_hs)
GT35R hopefully
Old Aug 18, 2005 | 07:55 PM
HT Black OPs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR &raquo;</TD></TR><TR><TD CLASS="quote">i plan on LS-T, the valve train i was looking at is as follows:
Crower 404 cams
Crower TI retainers
Crower Cam gears
Crower valves
Block:
CRP pistons 8:5:1
And what piston spec i should get?? will forged pistons still work with the same stock bore??</TD></TR></TABLE>
Old Aug 18, 2005 | 10:11 PM
HT Black OPs
need help!
lilshady6796
11
Jan 18, 2010 03:08 PM
katanamast279
Jun 8, 2009 10:57 AM
bukydc5
Aug 6, 2008 02:17 PM
TOTAL-TUNING
May 3, 2007 12:23 PM
