turbonetics manifold problem
Old Aug 16, 2005 | 06:45 PM
AlpineIntegra01's Avatar
Default turbonetics manifold problem
I have the new turbonetics manifold (the one with the wastegate in the center) and wehn it comes time to bolt the manifold up with the turbo it hits the block. I notched the block to give me the clearance but the back of the turbo just hits the block. Did anyone else have this problem? What should I do?
Old Aug 16, 2005 | 06:55 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: turbonetics manifold problem (AlpineIntegra01)
if i remember correctly you have to use that manifold with the compressor placed on the drivers side
Old Aug 16, 2005 | 09:45 PM
PYITR821's Avatar
Default Re: turbonetics manifold problem (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">if i remember correctly you have to use that manifold with the compressor placed on the drivers side</TD></TR></TABLE>
I want to know also....I have this manifold too btw....lol
Modified by PYITR821 at 6:59 PM 8/17/2005
Old Aug 17, 2005 | 03:47 PM
yeah i was thinking that is the only way to get it to fit. Will the older turbonetics or drag manifold have this problem also?
Old Aug 17, 2005 | 04:24 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (AlpineIntegra01)
the older drag manifold wil fit the turbo with the inlet facing the passengers side but you still have to grind down the block
Old Aug 17, 2005 | 06:13 PM
Well my block is already notched due to the fact i tried to get it to fit so thats not a problem. I rather just a new manifold because it cheaper and easier then buying a new turbo.
Old Aug 17, 2005 | 07:02 PM
wantboost's Avatar
Who is Mr Robot?
well the turbo is meant to be used with a 5-bolt turbo if i iremember correctly, not a 4
magefa
May 19, 2008 03:20 PM
PHOBIA
Dec 22, 2004 07:13 AM
Patron
14
Dec 9, 2003 01:34 PM
yellowturbo
Nov 28, 2003 05:11 AM
