who uses a little nitrous with boost?
I'm just wondering if a lot of people use nitrous with boost. If so how much boost and juice...
I currently run 15psi on the street, and plan to run 20-22psi at the track. but i also have a nitrous express wet kit on my car. I was thinking about spraying a 35shot wet on there with lowboost and highboost and see how it runs... Now when i used to spray a lot more i would take some timing out. Should i take any additional timing out for only a 35 shot??? Thanks
Re: who uses a little nitrous with boost? (fast93accord)
mrbsponge run a shots ontop of his boost. You might want to talk to him.
Also, we were getting ready to use a small shot to help with some turbo lag. Basically we were going to have it spray at 100% throttle, 0in/Hg and have it turn off at 8lbs of boost pressure. Glad we didn't get to that point because at 14lbs of boost the oil pump failed, oil pump gear failed and rod bearings spun Once the new motor is up and running we will be doing the same.
