boost & high compression
Old Aug 15, 2005 | 01:17 PM
93b16delsol's Avatar
Default boost & high compression
ok guys i built a b16 with arias 12.1 pistons, eagle h beam rods, deckguard, 340cc injectors, hondata s200,& all bolt ons. wanted to get 200 whp b16, but it is just to slow. i was thinking of nos but dont want to be aggravated with filling the bottle. my question is would it be possible to boost this motor reliably or im i just **** out of luck. im not wanting to do ne thing outrageous like under 10lbs & a small turbo maybe even supercharged.
Old Aug 15, 2005 | 01:31 PM
Chunty Butt Kevin's Avatar
tuning, tuning, tuning, maybe delay vtec
Old Aug 15, 2005 | 03:48 PM
Nidius's Avatar
Default Re: (Asians tyPe LiKe thIS yO)
Don't go with a small turbo.
1) Small turbos have lousy efficiency, and heat the air more at higher boost levels.
2) You will spool the **** out of it, and create detonation with super-heated intake temps.
Stay away from superchargers.
1) The positive displacement type is the only kind that's worth the effort on small engines, but it heats the **** out of the air.
You might want to consider getting new pistons, and removing that blockguard while at it.
If not, then try getting some good to tune it, and run some form of alky or water injection. I prefer alcohol myself, because it burns too. Water can be tricky, and it's hard to get the metering 'just right'. Your best bet is to find a way to get those intake temps as low as possible, that's the safest way to run higher compression with boost.
Old Aug 15, 2005 | 04:30 PM
Naterror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Asians tyPe LiKe thIS yO &raquo;</TD></TR><TR><TD CLASS="quote">tuning, tuning, tuning, maybe delay vtec</TD></TR></TABLE>
Thats the only way. Top Fuel cars run 14:1 compression then they run 26psi out of that big blower on top of it. It's all about tuning. But it's not going to happen on pump gas.
Old Aug 15, 2005 | 04:44 PM
green93SiT's Avatar
get someone really good to tune it u may even have to travel out of state.
Old Aug 15, 2005 | 04:55 PM
tony1's Avatar
Default Re: (green93SiT)
NO tuner is going to make that happen reliably unless you run methanol. Put a thick headgasket on it or change the pistons...
Old Aug 15, 2005 | 04:58 PM
dc2legend's Avatar
Default Re: (Naterror)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Naterror &raquo;</TD></TR><TR><TD CLASS="quote">
Thats the only way. Top Fuel cars run 14:1 compression then they run 26psi out of that big blower on top of it. It's all about tuning. But it's not going to happen on pump gas.</TD></TR></TABLE>
Lol. Top fuel cars run WAY more boost than that.
Old Aug 15, 2005 | 05:08 PM
tony1's Avatar
Default Re: (dc2legend)
And they damn sure don't run gas!
Old Aug 15, 2005 | 05:32 PM
Default Re: (tony1)
i dont really know much about alcohol injection but would that be more efficient than an intercooler sprayer.... and what kind of head gasket would u guys reccomend & around what compression would it take it down to
Old Aug 15, 2005 | 05:40 PM
tony1's Avatar
Default Re: (93b16delsol)
I would try and get it to around 9 - 9.5:1 with the headgasket.
Old Aug 15, 2005 | 05:56 PM
Default Re: (tony1)
wow i didnt know u could lower the compression that much by changing the headgasket. well if nething else comes to mind please let me know otherwise im bout to start looking for parts thanks guys
Old Aug 15, 2005 | 08:12 PM
downeyballz's Avatar
just rev your b16 higher, i would say keep it all motor and rev to 10,000. would bottom end can handle it just upgrade you valves and springs
Old Aug 15, 2005 | 08:17 PM
tony1's Avatar
Default Re: (downeyballz)
You can rev an N/A b16 all you want, but it still won't compare to a turbo B16.
Old Aug 16, 2005 | 05:27 PM
Default Re: (tony1)
so would it be worth the time & money to try & boost it bc it will be expensive, or would say a 75 or 100 shot be more logical with reliabilty in mind
Old Aug 16, 2005 | 05:39 PM
EBP.EM1's Avatar
i would put in lower compression pistons if you are going to turbo it.
Old Aug 16, 2005 | 05:58 PM
Default Re: (LSVtec-T)
yea that would be the smart thing but i dont have another car to drive to work while the new pistons would be put in......& i didnt have the money at the time of the build for a turbo wish i would have done things differently.. oh well i guess nitrous it is.
Old Aug 16, 2005 | 06:34 PM
b18b1ls1's Avatar
Or they run about 45 psi of boost and 6.0:1 compression! Close though!
Bonestock98GS
Apr 9, 2009 07:43 PM
92civtegra
Aug 15, 2007 08:26 PM
deemack79
Feb 14, 2005 05:33 PM
my crx is rhd
Dec 27, 2004 12:59 PM
BOOSTED-EG
Jun 17, 2004 05:33 PM
