PLX m300 install.... open downpipe sensor placement?
Old Aug 15, 2005 | 11:29 PM
LSTEG96's Avatar
Default PLX m300 install.... open downpipe sensor placement?
can i place the wideband sensor at the end of the open down pipe? or is this a bad place because the open air is so close.. with exhaust gasses being expelled constantly the open air near it should really matter should it??
Old Aug 15, 2005 | 11:47 PM
ATS*Mark's Avatar
OG triple OG
Default Re: PLX m300 install.... open downpipe sensor placement? (LSTEG96)
mines like 4 inches from the opening of the downpipe.
Old Aug 15, 2005 | 11:50 PM
LSTEG96's Avatar
Default Re: PLX m300 install.... open downpipe sensor placement? (Hella_JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">mines like 4 inches from the opening of the downpipe.</TD></TR></TABLE>
damn. mines right on the end... i welded it on not REALLy thinking about it, now im having second thoughts... before i fire up the completely new motor/turbo setup should i move it? its open down pipe and the end is flex pipe, should i move it to before the flex pipe? i really need the readings to be correct!
Old Aug 15, 2005 | 11:53 PM
ATS*Mark's Avatar
OG triple OG
im not too sure actually , i know there are "optimal" places to put it , mine might not even be right.
Old Aug 15, 2005 | 11:57 PM
LSTEG96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">im not too sure actually , i know there are "optimal" places to put it , mine might not even be right.</TD></TR></TABLE>
yeah, 24 inches or something, because the sensor cant be more than 850* celcius... anyone know if there is enough flow from the exhuast at idle and everything so outside air ISNT contaminating the O2 reading?
Old Aug 16, 2005 | 08:39 AM
LSTEG96's Avatar
bump
Old Aug 16, 2005 | 11:38 AM
LSTEG96's Avatar
anybody?
Old Aug 16, 2005 | 05:03 PM
LSTEG96's Avatar
Default Re: (LSTEG96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 &raquo;</TD></TR><TR><TD CLASS="quote">anybody?</TD></TR></TABLE>
Old Aug 17, 2005 | 07:30 AM
LSTEG96's Avatar
up.
Old Aug 17, 2005 | 08:51 AM
adseguy's Avatar
nope it'll contaminate at idle and even WOT if it's close. I have it 8inches or so ad I still get a little contamination at idle. It doesn't take much at all to contaminate.
Old Aug 17, 2005 | 10:50 AM
LSTEG96's Avatar
Default Re: PLX m300 install.... open downpipe sensor placement? (adseguy)
damn, how do u know if its contaminated? when it says air, or do u just know that your reading is off?
Old Aug 17, 2005 | 12:16 PM
adseguy's Avatar
the reading will be leaner, but I know it was leaner because of the open DP because once i put the full exhaust on it went away.
Old Aug 17, 2005 | 08:51 PM
LSTEG96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">the reading will be leaner, but I know it was leaner because of the open DP because once i put the full exhaust on it went away.</TD></TR></TABLE>
the car will actually run richer with a full exhaust, no??
Freemananana
Oct 22, 2020 10:00 PM
kte324
Feb 1, 2010 12:52 PM
ericstambaugh07
Mar 18, 2007 05:35 PM
the soL that could
Welding / Fabrication
Mar 15, 2006 04:14 AM
Luserkid
Sep 9, 2005 09:14 PM
