boost but no power...........
I’ve tried to figurer this out by myself for sometime now. At one point my turbo would show boost below 3000rpms in first gear but no power. Now it shows boost at 4000rpm and only after getting into second with a little power. I’ve run compression and leak down test. The numbers are fine on comp test and the leak down is within tolerance. My vac gauge reads 21 at idle. I’ve checked the bov for leaks and the piping as well. I’ve fixed all my vac and oil leaks. The turbo is rebuilt. I blow no smoke. The gas is 93 octane and I’ve play with the timing. I’m stuck like Chuck now….. Please help. The car is a prelude with b20a and T3 turbo .48/.49.
Thanx
Thanx
Don't have any engine management at this point. I can't rember the exact gapping on the plugs. Right now I just have a fmu and a performance gas pump. I want to get the bugs worked out berfore spend money and anything else.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OMegaSupreme »</TD></TR><TR><TD CLASS="quote">Don't have any engine management at this point. </TD></TR></TABLE>
i dont know but that might have something to do with it
DEMNTD1
Jul 20, 2005 08:25 AM
