help!
Old Aug 16, 2005 | 12:52 PM
dbwsi's Avatar
Default help!
I have a 2000 si. I have vortech fmu, vafc, and dsm 450 injectors. Vafc is not tuned yet and i just wired in the 450 injectors. After i wired in the injectors the car misses bad at idle and stumbles when you give it gas. I double checked the wiring and everything is right. Vacuum flucuates at 10in hg. Any suggestions?
Old Aug 16, 2005 | 12:56 PM
EBP.EM1's Avatar
you have to set the afc to -30% to -40% to offset the new injector size. also you dont need an fmu when you run bigger injectors.
Old Aug 16, 2005 | 06:53 PM
dbwsi's Avatar
Default Re: (LSVtec-T)
I took out the fmu. Under what setting do u adjust it to -35 to -40%
Old Aug 16, 2005 | 06:54 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: help! (dbwsi)
cant use 450cc injectors and the fmu together
Old Aug 16, 2005 | 09:36 PM
knomexx's Avatar
Default Re: help! (wantboost)
under the narr throttle and wide throttle settings. you have to adjust it across the whole rpm range
Old Aug 17, 2005 | 05:03 AM
dbwsi's Avatar
Default Re: help! (knomexx)
cool thanks
hxtasy
Jun 5, 2005 01:11 PM
flarinpnoi
Mar 28, 2004 12:46 AM
MikeMAN
Feb 1, 2003 10:23 PM
civictypenos
Oct 19, 2002 05:28 PM
echo999
Jun 13, 2002 07:48 AM
