501whp GSR/Turbo Tuned by Raceline
501whp GSR/Turbo Tuned by Raceline Tuning
84mm B18c
.68 a/r T4
1000cc Precisions
255lph Walbro
stock gsr head
DPR valve train
Kteller 3" exhaust
Raceline 3" downpipe
Car trapped 104mph in the 1/8th. Havent made a full 1/4 mile pass yet. Had some boost issues we had to work out.
26psi
c16
whatcha think?
http://racelinetuning.easystor....asp
Modified by Tuned1 at 3:56 PM 8/19/2005
Modified by Tuned1 at 4:03 PM 8/19/2005
.68 a/r T4
1000cc Precisions
255lph Walbro
stock gsr head
DPR valve train
Kteller 3" exhaust
26psi
c16
whatcha think?
Re: 501whp GSR/Turbo Tuned by Raceline (boosted92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92 »</TD></TR><TR><TD CLASS="quote">".63 a/r T4" doesn't really tell us much about the turbo, but needing 26 psi to make 500 WHP sounds like a lot of boost for a full T4 turbo.</TD></TR></TABLE>
Yea, does sound like alot of boost for only 500+. I would have thought, it'll easily be in the 600+ mark at that boost level on a T4... <head scratch> unless it has a small T3 hot side...
Re: (cubish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cubish »</TD></TR><TR><TD CLASS="quote">should be making a lot more power with a pt67 imo. </TD></TR></TABLE>
Agreed, even on a mustang dyno. tygsr made 593 WHP @ 25 psi on an 81.5mm bore motor, and servion made 598 WHP @ 25-27 psi on a T3/T67 on an 81.5mm motor. The only big bore PT67 dyno I could find was hybrid901's, who made 620 WHP @ 26 psi on an 84.5mm motor.
Re: (boosted92)
There is still room left in the tune. Very conservative. But Im not seeing 100whp gains. Not saying those other guys dyno # arent true either. Those are all great numbers for that amount of boost. Any idea of what those cars weight and 1/4 trap speeds are? Set ups?
Re: (Tuned1)
hybrid901 has "10.66 @ 142" listed in his sig, but you should ask him for the weight and boost level on that pass.
servion has <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by servion »</TD></TR><TR><TD CLASS="quote">SFWD Streetcar at ~6000ft elevation driven 65 miles to the track and home:
10.7 @ 134 & 11.1 @ 137</TD></TR></TABLE> in his sig, and since he runs SFWD his car has to check in at a minimum of 2400 pouds.
tygsr never posted about going to the track and he ended up selling his car.
Re: (boosted92)
NICE! I would also like to no there 1/8th mile mph and time to compare to ours was a 7.7 @ 104, since we havent made a full pass yet. fyi, Hondas (hatches) that put down around 500-550 whp on our dyno will trap around 138-140 mph. I just wanted eveyones opinions on the graph, more so than the hp numbers...
Good graph guys, the torque dosent fall off like most you see on H-T and the powerband is great!
Dont let the more accurate numbers from the mustang dyno fool you. Very solid 1/8 times so far cant wait for some full passes. There are some badass hondas coming from your guys shop. Good vids on your site also.
Re: (Widebody1)
I was thinking the same thing.
I believe Tygsr went 110mph in the 1/8 with his clutch letting go shortly after the 1/8. It was the first and only time out to the track and I think it still coasted to a mid 11. I believe the car was full weight minus the A/C.
Re: (cubish)
i did that on 15-16lbs with pt67, but none-the-less 104mph in 1/8th it good for low 7 and high 10 depending on car 1/4. and welcome to the 500club
Re: (Black DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black DC2 »</TD></TR><TR><TD CLASS="quote">damn stop hating on him nice job </TD></TR></TABLE>
it's not really hating, it's just that compared to others with that turbo the numbers are sub-par. great numbers none the less but i would think it should be a little better.
that is a pretty good powerband though. talk about a flat torque curve...
Re: 501whp GSR/Turbo Tuned by Raceline Tuning (Tuned1)
For a mustang dyno (i could only manage 331 on one ) I think your #'s are great! For reference, one of the local shops has a dsm (stripped/roll cage/built motor, etc) that could only put right around 500 on a mustang awd dyno and the car ran a 10.1 @146...
Re: 501whp GSR/Turbo Tuned by Raceline Tuning (PhoenixTurboJesse)
its all how u set up those dynos...
ive seen the opposite too.
where a car made like 412 on a mustang and only 360 something on a dynojet
