need help with pipes
Old Aug 14, 2005 | 10:00 PM
EJ8 GSR-T's Avatar
Default need help with pipes
is there any way to creat my own pipes with out any special machinery for my turbo setup? basically intercooler pipein?
Old Aug 15, 2005 | 05:28 AM
pdc125's Avatar
Default Re: need help with pipes (userdead626)
I bought a bunch of aluminized steel U-bends from JC Whitney for ~15 each. I think I used up a total of 4 bends, and a small piece of straight to do the piping on my integra.
I just had a chopsaw with a metal cutting wheel, a bench grinder and belt sander to clean up the seams to weld, and a crappy welder to tack weld them. Technically you just need something to cut them, and just mark them if you're having them welded someplace else. A band saw is also good for cutting piping, and I've even known people who've used just a sawzall.
Just make sure to cut at the proper angles on the bent parts, or you'll end up with crazy ovals that won't fit properly to anything.
Gr8DC2R
Welding / Fabrication
Nov 11, 2007 06:45 PM
Blanket Jackson
Apr 6, 2004 05:03 PM
JDEM1
Aug 31, 2003 12:14 PM
Acura_I-RS
Mar 12, 2003 07:37 PM
buck02
Jan 26, 2003 05:16 PM
