What to use to clean engine block?
Old Aug 19, 2005 | 11:19 AM
d16dcoe45's Avatar
Default What to use to clean engine block?
I was wondering what you guys use, or what is the best solvent to use to clean a block after tearing down a motor to rebuild it? Mainly talking about the inside of the block-cylinder walls, oil channels, inside the main bearing saddle etc. I have a Moroso nylon bristle engine brush set I am going to use, but what solvent? Acetone, paint thinner, mineral spirits, isoproyl alcohol, ethyl alcohol? Or some sort of brand name commercial degreaser? The block is painted and I know acetone will remove some of the paint (which I don't want-if I want to remove the paint, acetone will do a half-assed job, I would use aircraft stripper), but I want to use something that won't leave any residue, brake cleaner? Help!
Modified by d16dcoe45 at 10:02 AM 8/21/2005
Modified by d16dcoe45 at 10:04 AM 8/21/2005
Old Aug 19, 2005 | 11:23 AM
mike1114's Avatar
Default Re: What to use to clean engine block? (d16dcoe45)
You first do this cause I personally just posted in another thread just like this today.
Old Aug 19, 2005 | 11:26 AM
King Tut33's Avatar
Default Re: What to use to clean engine block? (mike1114)
Another words click his name and go to his watched topics and click on this link:
https://honda-tech.com/zerothread?id=1344528
Old Aug 19, 2005 | 01:10 PM
EJ1 wilcox's Avatar
Default Re: What to use to clean engine block? (King Tut33)
I used some plain old Castrol degreaser stuff... in a purple bottle... and a pressure washer.
I just let it soak for a bit and sprayed it off. You shold have seen this block before, you couldn't even see anything but black oil and **** all over the place, it was nasty...
Looks better now though. It's not perfect, but it cost me $3 and about 30 minutes so I'm satisfied.
There are a lot of different methods, just use one that's easy for you.
Old Aug 21, 2005 | 08:58 AM
d16dcoe45's Avatar
Default Re: What to use to clean engine block? (EJ1 wilcox)
Thanks alot guys--the search function hasn't been working for me for the past 2-3 days--it always says "try later on". Also, when I do search--its seems like you have to put the EXACT words of the post--or else nothing comes up--is there a method of searching to find what you want? You understand what I am trying to say? Also, I really wasn't concerned about the outside of the block--more the oil channels and getting all that crap out--I have heard that pain thinner gets absorbed (at least with cast iron) into the metal and seeps out slowly later on--so even though paint thinner seems like the best solvent to use I don't want it to seep into my block and then thin the oil later on when the motor is running.....
Old Aug 21, 2005 | 09:59 AM
PhantomX's Avatar
Brake cleaner?...... i heard that stuff cleans like crazy
Old Aug 21, 2005 | 11:13 AM
AspectIndustries's Avatar
Default Re: (PhantomX)
They also make engine cleaner? Spray it down, Let it soak, then Rinse! Easy as that. Gunk! $1.49/$1.99 a can!
Works for me.
Old Aug 21, 2005 | 11:22 AM
Si Shane's Avatar
Default Re: (synik)
gasoline + rag = success.
Old Aug 21, 2005 | 02:08 PM
eg crunkmonster's Avatar
Default Re: (Si Shane)
brake parts cleaner will clean off any grease build up guarenteed
Old Aug 21, 2005 | 03:03 PM
AlphaQup's Avatar
Default Re: (eg cookiemonster)
Don't forget goodole Simple Green and a toothbrush.
Old Aug 21, 2005 | 10:27 PM
JSpin's Avatar
Default Re: (AlphaQup)
i used simple green, wire brushes, and the sponges with scotch brite on one side. my b16 was about the dirtiest motor you could imgagine. it had a bad oil leak and was then in a roll over accident where it got covered in dirt, and then sat for 6mon or so. i was able to get it about as clean as EJ1's pictures, defnitely presentable.
Old Aug 22, 2005 | 02:49 AM
jDMJeRk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16dcoe45 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks alot guys--the search function hasn't been working for me for the past 2-3 days--it always says "try later on". Also, when I do search--its seems like you have to put the EXACT words of the post--or else nothing comes up--is there a method of searching to find what you want? You understand what I am trying to say? Also, I really wasn't concerned about the outside of the block--more the oil channels and getting all that crap out--I have heard that pain thinner gets absorbed (at least with cast iron) into the metal and seeps out slowly later on--so even though paint thinner seems like the best solvent to use I don't want it to seep into my block and then thin the oil later on when the motor is running..... </TD></TR></TABLE>
Searching can be a pain in the *** sometimes.... I just had my block painted after the machine shop hot tanked it. No crazy color but a light grey. LoL I remember asking them "damn my block was that clean!" and they said no, its just paint lol.
Old Aug 22, 2005 | 03:40 AM
ef92b's Avatar
Default Re: What to use to clean engine block? (jDMJeRk)
hello guys,
i've bought this junky B 6 months ago for cheap and work is still in progress. stopped for a while now due to budget constraints but hope to finish it soon. this is my first ever B project and i wanna build it right the first time
i cleaned everything out of this block with a soft wirebrush(attached on a drill), gasoline, carb cleaner and engine degreaser. what i did was to spray all the external parts of the block with the degreaser, leave it for 10 minutes and start brushing off the dirt using a 2" paint brush soaked on gasoline. make sure u do this on a well ventilated area ... do refrain for a while smoking on some stuborn areas, use the carb cleaner for better strenght. then use the paintbrush soaked on gas afterwards.
when i just had it:
see how clean it is??
my homie engine stand.
start working will yah
and so...
the cyl head how it looked like as well
after a while:
how it looked like before i took it for a PnP job. i don't have a current pic out of the PnP job coz i kept it sealed for now due to delays of the rebuild.
and don't forget to have your hands clean too
more pics on my sig. thanks for viewing
Old Aug 22, 2005 | 04:31 AM
Dee's Avatar
Dee
I used foaming Simple Green in the aerosol can and a wire brush.
1991hondahead
11
Sep 21, 2004 05:00 PM
firstgenrex
23
Oct 9, 2003 02:01 PM
DeDonDeRosa
Apr 4, 2003 11:06 AM
xXx Justin xXx
14
May 21, 2002 10:24 AM
B_CRUZ!
Mar 14, 2002 06:30 AM
