What Pistons and Rods
Old Jun 29, 2006 | 07:11 PM
x91crxsix's Avatar
Default What Pistons and Rods
I was wondering what pistons and rods i should use for my ls/vtec turbo project to keep the compression fairly low for a daily driver?
Old Jun 29, 2006 | 07:19 PM
96 GSR-T's Avatar
Default Re: What Pistons and Rods (x91crxsix)
I use Wiseco & Crower Steel Billetts
About $1100+ for the combo
JE Pistons & Eagle Rods will be cheaper
Deciding exactly what size dish to get depends on whether your block and/or head has been milled and then you can pick a headgasket sized to obtain your desired compression ratio.
Old Jun 29, 2006 | 07:25 PM
x91crxsix's Avatar
Default Re: What Pistons and Rods (96 GSR-T)
yea i was thinkin of getting eagle rods and je forged pistons, what would that put my compression at?
Old Jun 29, 2006 | 07:28 PM
96 GSR-T's Avatar
read my previous post, had the block been milled and/or the head? When you order pistons it says what pistons will achieve said compression ratio, those #'s are with a stock block, but on an LS/Vtec its a little different, has your head and block been milled/surfaced at all, what VTEC head are you using? I cant just spit a # at you without details
Old Jun 29, 2006 | 07:31 PM
x91crxsix's Avatar
sorry didnt see the full post , no the head isnt milled or anything, its a b16 head.
Old Jun 29, 2006 | 07:39 PM
bamboosted's Avatar
I have Endyn pistons and egale rods in my ls/vtec. I like the endyns cuz they sound nice and stock .. I had so JE i didn't like the but its just my two cents .
Old Jun 29, 2006 | 07:43 PM
x91crxsix's Avatar
Default Re: What Pistons and Rods (bamboosted)
bamboosted, can u tell me what ur whole setup is for ur boosted ls/vtec?
Old Jun 29, 2006 | 07:47 PM
96 GSR-T's Avatar
With a stock sized headgasket you will need a piston with about a -9.3 dome to get exactly 9:1, its best just to call a shop on here and tell them what you got and what you are looking for.....
bamboosted's Avatar
81.5mm endyn 9.0.1 comp pistons ,eagle h beams, all new honda bearing and pumps(water and oil), B16 head stock right now soon to have ctr cams and supertech valvetrain or omnipower valvetrain no sure yet on that part ..with Edlebrock Intake mani + 65.mm tb. honda timing belt, and my old turbo set up was a t3/60-1 on a ramhorn mani with 3inch dp.
Old Jun 29, 2006 | 07:48 PM
x91crxsix's Avatar
alright, thanks for ur info
Old Jun 29, 2006 | 07:51 PM
x91crxsix's Avatar
how much horspower and torque are u making and whats it in?
Old Jun 29, 2006 | 08:09 PM
bamboosted's Avatar
357whp 259wtq @ 12psi.
agp1183
Jan 23, 2006 01:35 PM
slowteg550
Jan 14, 2006 04:28 AM
Speedz
Dec 29, 2001 02:36 AM
