Keeping Elec Boost Gauge Calibrated.
Old Jun 30, 2006 | 07:54 AM
ctownintegra's Avatar
Default Keeping Elec Boost Gauge Calibrated.
Got it all hooked up and all those wires stuffed back in there and then realized the red wire is supposed to stay on a power source even when starting the vehicle. Where can I tap into for that? I was thinking maybe the fuel pump?
Old Jun 30, 2006 | 08:16 AM
Importordomestic's Avatar
Default Re: Keeping Elec Boost Gauge Calibrated. (ctownintegra)
just use a volt meter to test on the fuse box for a constant 12v, and hook that wire up there. the other 2 common places to find 12v+ all the time is the memory wire for the radio or the cig lighter.
Old Jun 30, 2006 | 08:31 AM
I can't use memory wire though, it needs to get power when I turn the car to on and keep it while starting the car.
Old Jun 30, 2006 | 09:11 AM
oscarmayer's Avatar
Default Re: (ctownintegra)
you need to get a test light ($9.95 at most auto stores for a chepo) and turn your key on the ignition 1 click.
now start checking the wires on the steering colom and find one that is light up. then turn the key off. if the light goies out whil still golding the tester to the wire and then you turn the key 1 click and it turns on, your set.
Old Jul 18, 2006 | 08:35 AM
B18EG6's Avatar
I am at work and dont have the picture handy, but there are 5 spots on the underdash fusebox. One is for 12v when the lights are on, one is for 12v when the ignition is on, and one is for 12v all the time. I believe the 12v constant is to the left
Use a multimeter and find out, not hard at all
wtemale
Nov 18, 2017 05:08 PM
crist488
Jan 16, 2010 04:42 PM
Shaynepolevault
Lighting
12
May 27, 2008 12:56 AM
tyflip2
Jun 14, 2004 03:08 PM
oryanh
Mar 26, 2003 02:00 PM
