Funky Oil Pressure Problems
I'm running an LS motor with a GSR oil Pickup & GSR Pan (welded-in fastline baffles).
My stock oil pressure light started flashing, so my friend installed his oil pressure gauge.
When I make a left turn (i.e. taking an off ramp), my oil pressure goes up - which I think is normal because I am accelerating.
When I make the same type of turn but LEFT, the oil pressure DROPS!
I can't verify the following because I didn't want to chance blowing this motor, but I noticed that after I redline the car (7k), the oil pressure will drop. Afterwards, even traveling at around 4k, the oil pressure will drop to about 1kilo-pascals and drop even more until my oil light starts flashing again.
After this round of testing, I changed the oil and did another test, and had the same results! Another thing I should note is that when I changed the oil, the oil drained like I was draining coolant (sounds like you have diarhea). The oil smells like the junk that collects in the catch can - fuel. Oil did NOT seem like it was contaminated with coolant. This oil also probably had less than 20 miles. I used some brake cleaner to clean the block and head, but I was careful to not get too much of it into the ports in the head.
One more thing! When my oil pressure light would flash, I would pull over and check the oil, and I could see bubbles in the oil on the dip stick.
Please help! Sorry for the long post, but I wanted to be as thorough as possible.
Setup:
Stock LS block & Head with GSR pickup & pan. Vtec waterpump, JDM vtec oil pump - used but clearances checked. Also, the mounting was modified to relocate the pickup so it would have the same height/depth in the pan since I am not running a vtec girdle.
Setup:
You may have welded in one of the baffles backwards. Instead of holding the oil in place, it is allows it to flow away from the pick-up.
Either that or the pickup is not placed properly and you are not getting the benefit of all the oil in the pan.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl »</TD></TR><TR><TD CLASS="quote">You may have welded in one of the baffles backwards. Instead of holding the oil in place, it is allows it to flow away from the pick-up.
Either that or the pickup is not placed properly and you are not getting the benefit of all the oil in the pan.</TD></TR></TABLE>
Thank you for the input. This oil pan did not have oil pressure issues on a previous order. I will double check the placement of the pickup, or just go with the LS pickup & pan to try and weed out any issues.
Are GSR/LS pumps interchangeable with pickups? Obviously the first step is to put the stock pump/pickup/pan setup on there and see if it fixes it. Do that and let us know the verdict.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecD »</TD></TR><TR><TD CLASS="quote">Are GSR/LS pumps interchangeable with pickups? Obviously the first step is to put the stock pump/pickup/pan setup on there and see if it fixes it. Do that and let us know the verdict.</TD></TR></TABLE>
Currently trying to locate a pickup & pan so I don't have to spend $150 on new ones.. maybe more if the baffle is not interchangeable. A little more money and I can pick up a used LS shortblock, maybe a longblock. I'll keep you posted.
Should have an LS oil pan & pickup by early next week.
Anyone have any ideas about why my oil had bubbles or why my oil drained like it was water?
After a member on HT decided not to ship my oil pan, baffle & pickup, I was able to buy one from ebay.
UPDATE:
The location where the pick-up mates with the oil pump was loose. Having the LS stuff, I decided to install all of it.
Problem now:
Oil pressure gauge goes to a max of 7kg/cm^2. Oil pressure stays above 6kg/cm^2 and tries to go past 7kg/cm^2 when I accelerate. Is having too high of oil pressure an issue?
Also, if anyone knows off hand, are the TPS sensors from cars containing the B18A compatible with the B18B? I had to pull the Map sensor off the B18B TB and mount it on another location because the B18A TB does not have a location to surface mount it. I used the vacuum hose on the barb sitting rough at 1 o'clock and plugged the larger barb that sits at 12 o'clock.
If anyone has any input, I would appreciate it. Car is currently running 10w40 dino oil, NO oil coolers, stock or aftermarket.
UPDATE:
Problem now:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime »</TD></TR><TR><TD CLASS="quote">what does 7kgcm^2 = in psi?
Normal oil psi is like 25-35psi at idle, 50-70psi cruising and like 80psi at 4k+</TD></TR></TABLE>
Psi x .0703 = kg/cm2
7kg/cm^2 = 99.573psi
6kg/cm^2 = 85.349psi
This is all below 4k RPM...
Currently my car is idling at like 1200-1500rpm and is REALLY jerking at part throttle. I'm trying to get the vacuum or TPS, MAP sensor problems solved...
Are there any issues I should be worried about with this high of oil pressure? Note that when I accelerate, somethings the needle pins the 7.
Thanks for the photos... but I just swapped in an LS pickup, baffle, & pan to avoid any further issues...
Looks like I have a huge vacuum leak right now. I think I have the other problems out of the way... except for the high oil pressure. Once I get the vacuum problem fixed, I'll be able to take it out for a longer drive and see if the oil pressure goes down.
An oil pump has a pressure release valve so as not to push too much pressure. As long as it's working you'll be fine. I get 95 psi at cold idle, 95 psi is the cutoff on honda pumps I believe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecD »</TD></TR><TR><TD CLASS="quote">An oil pump has a pressure release valve so as not to push too much pressure. As long as it's working you'll be fine. I get 95 psi at cold idle, 95 psi is the cutoff on honda pumps I believe.</TD></TR></TABLE>
My gauge wants to go past 100psi... or past 7kg/cm^2... it's just being stopped by the pin that limits it's motion...
Supahr_Ed
May 27, 2006 11:51 AM
Snafu-Si
Mar 24, 2003 10:47 PM
