oil pan
Old Jun 29, 2006 | 02:56 PM
teamV eg's Avatar
Default oil pan
i have everything for my turbo except for the tap for the oil pan i was wondering what is the best way to go about tapping it for my return line thanks
Old Jun 29, 2006 | 04:29 PM
skiwithcars's Avatar
Default Re: oil pan (TV00ek)
drill hole. then weld bung or braze fitting
Old Jun 29, 2006 | 04:34 PM
96 GSR-T's Avatar
Default Re: oil pan (skiwithcars)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skiwithcars &raquo;</TD></TR><TR><TD CLASS="quote">drill hole. then weld bung or braze fitting</TD></TR></TABLE>
Dont just tell him to drill a hole......
Make the fitting as high as possible or the oil cant drain, or just buy an oil pan with the bung already installed.
Old Jun 29, 2006 | 05:28 PM
dpetro1's Avatar
this might be pretty simple depending on your setup but what i would do is mount the turbo, mani and dp, dump and maybe even some of the hotside charge pipes. then put on the return line and see what the best route would be. you want the fitting mounted as high as possible like stated easlier. mark it then remove the oil pan, drill your hole and get the fitting welded. or you could use a weldless setup if absolutely necessary.
take your time with it and make sure you have a nice, downward sloping line with no kinks. its gonna be a pain if you ever have to move the fitting or redue the line cause of smoking issues.
Old Jun 29, 2006 | 05:33 PM
Naterror's Avatar
I personally like the bulkhead fitting setup better. It's better against leaks vs. bung and brass fitting from what I've seen.
https://honda-tech.com/zerothread?id=1312904
Old Jun 29, 2006 | 08:12 PM
teamV eg's Avatar
you think i could find an oil pan with the fitting already on ebay or something?
Old Jun 30, 2006 | 11:58 AM
dpetro1's Avatar
Default Re: (TV00ek)
well the moroso pan has a fitting on it already. but if something happens and that location doenst work for you, then you are kinda screwed. its really not that hard to just tap the pan yourself.
dan89crxsi
May 31, 2007 08:00 AM
si0385.
Oct 22, 2006 09:19 AM
Layziebtnh055
May 16, 2004 10:09 AM
Steve91
May 29, 2003 08:43 AM
b00stedsi
Jul 28, 2002 04:17 PM
