advice on new setup (from the experts)
Old Jul 2, 2006 | 04:58 AM
craigbrk's Avatar
Default advice on new setup (from the experts)
hey lads just sold my celica today and im collecting my new car next week its a civic b16a turbo heres the spec;
B16A2 1.6 TURBO CURRENTLY RUNNING 260 BHP AT 7 PSI BOOST ON STANDARD INTERNALS
CHROMALLOY ULTRA LIGHTWEIGHT FLYWHEEL
550 CC INJECTORS
BLITZ AIRFILTER
PEAKBOOST STAINLESS STEEL EQUAL LENGHT EXHAUST MANIFOLD MADE OF 321 8 GAUGE STAINLESS STEEL
GARRET T3/TO4E TURBOCHARGER
TIAL 38MM EXTERNAL WASTEGATE AND SCREAMER PIPE
PEAKBOOST GARRET CORE 24X6X3.5 INTERCOOLER (2.5" INLET AND OUTLET)
TIAL BLOW OFF VALVE
TIG WELDED 2.5" CHARGE PIPING
3 INCH DOWNPIPE
UBERDATA CHIPPED ECU
WALBRO UP RATED FUEL PUMP
ACT UPRATED CLUTCH PLATE AND PRESSURE PLATE
right lads thats the spec on the car at the mo .so now he says ill need gasket set,shells for the bottom end , (bearings,big ends and main bearings) to complete the set up just need any advice whatsoever on this lads as im new to to all this engine building crack this is the rest of the stuff i bought off him
1.8 integra block b18c been overbored .25 i have wiseco pistons to match and eagle rods
act extreme pressure plate and clutch plate an eagle block guard i have skunk 2 adjustable front camber arms and rear omni adjustable camber arms oh and another turbo manifold
and i have a 14.5 psi spring or 1 bar
and ive been told it should run 360-380 bhp on that block with my setup
1) would it be a wise decision to change the bearings to new ones the ones that are in it are fine but with the extra hp would it wise to get fresh shells?
2) would i need a new oil pump , again the one in the car is fine but just in case dont realy want to go changing this either unless i have too ,
3) i need a gasket set, would a standard gasket set for the b18c do from ebay?? and the head gasket can anyone recomend which head gasket i should go for hks , apexi etc and wat thickness would be the best???
cheers in advance lads,need advice from the experts
Old Jul 2, 2006 | 06:03 AM
craigbrk's Avatar
Default Re: advice on new setup (craigbrk)
anyone????
Old Jul 2, 2006 | 06:07 AM
Silverhatch's Avatar
I think that if you want to make 380whp u should build the motor.
Old Jul 2, 2006 | 06:10 AM
craigbrk's Avatar
Default Re: advice on new setup (Silverhatch)
i am building the motor bud,but need a few questions ans
Old Jul 2, 2006 | 06:47 AM
dornon13's Avatar
change:
oil pump
water pump
bearings rods and mains
timing belt/tensioner
all gaskets
get a stock headgasket they work just as good as any other
your engine build is not something to skimp on it is the hardest to get to and can be a very big headache. do it right the first time it wont cost you THAT much. and if you cant afford it then maybe you shouldnt be building it anyways.
Old Jul 2, 2006 | 08:48 AM
craigbrk's Avatar
Default Re: advice on new setup (dornon13)
im not going to skimp on it man.
right now ive got the b18c bottom end bored out .25 with wiesco pistons and eagle rods to match , i want it to be safe thats why im lookin for advice.i will also be changing all the belts etc. so a stock head gasket will do??can i have a second opinion on this???bearings rods and mains????
Old Jul 2, 2006 | 09:10 AM
dornon13's Avatar
you definately need to change the bearings even more so than the belts...you can get by without changing the belts but think about it...what happens if your bearing spins and locks up....oops now my crank is bad all for saving like 100 bucks
Old Jul 2, 2006 | 10:45 AM
craigbrk's Avatar
anyone got a link for a full gasket set for a b18 also full bearing set also for the same. not gona take any shortcuts
Old Jul 2, 2006 | 12:32 PM
dornon13's Avatar
http://www.hondaautomotiveparts.com/
you can get all your OEM parts here...or your local honda dealership...ive found it is usually about the same price after shipping. If you dont have the tools to build it yourself i would recommend having someone do it. You can do it yourself but its safer to have someone experienced do it. But with that said you have to start somewhere.
just a side note...look up camber kits....im not sure you understand what they are.
Old Jul 2, 2006 | 01:04 PM
craigbrk's Avatar
just a side note...look up camber kits....im not sure you understand what they are.[/QUOTE]
lol my bad cheers buddy will do my mistake.
Old Jul 2, 2006 | 02:53 PM
96 GSR-T's Avatar
A camber kit adjust the angle of your tires, if your car is lowered you will notice that the tires and wheels lean in towards the canter of the car, when you intall the camber kit, you take the car to an alignment shop so that the wheels and tires can be made straight up again..... easiest way for me to put it.
JDMH22HATCH
Texas -OK -LA (Sales)
21
Oct 24, 2007 12:11 PM
JDMH22HATCH
Aug 3, 2007 05:47 PM
craigbrk
Jun 28, 2006 08:06 AM
craigbrk
May 24, 2006 04:29 AM
blackeg
Apr 19, 2004 09:54 AM
