Digi Key map sensor - Two nipples :O
Old Jun 29, 2006 | 11:50 AM
coneheadsracing's Avatar
Default Digi Key map sensor - Two nipples :O
I ordered a couple of sensors off digi key, i found a part number on here, and entered it, three came up, two were out, and one in stock. 36 psi i believe. Anywyas, theres two nipples, any one know why? Is it like an in out type of thing. It looks like the other ones i see on here are just one inlet. Otherwise they look like the same sensor.
Old Jun 29, 2006 | 04:47 PM
Default Re: Digi Key map sensor - Two nipples :O (coneheadsracing)
Boost is fun
Old Jun 29, 2006 | 05:10 PM
BB6-213's Avatar
I like nipples, especially two of them. Sorry...I am no help.
Old Jun 29, 2006 | 05:13 PM
Default Re: (BB6-213)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB6-213 &raquo;</TD></TR><TR><TD CLASS="quote">I like nipples, especially two of them. Sorry...I am no help.</TD></TR></TABLE>
I guess it could be worse, there could of been three..... who knows, i'll just hook it up tommorow, and see what the hell happens.
Old Jun 29, 2006 | 05:20 PM
k24em2's Avatar
Default Re: (coneheadsracing)
Whats the part number?
Old Jun 29, 2006 | 05:42 PM
Default Re: (k24em2)
MPX4250DP-ND
Old Jun 29, 2006 | 06:05 PM
USDM 4G VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coneheadsracing &raquo;</TD></TR><TR><TD CLASS="quote">MPX4250DP-ND</TD></TR></TABLE>
theres your problem
the DP after 4250 means is a dual port
the right map sensors are MPX4250AP wich are single ported and they are out of stock everywhere
and in case you get the single ports, i fabricate the single port adapters
Old Jun 29, 2006 | 06:22 PM
eh3 93's Avatar
Default Re: (USDM 4G VTEC)
Nice piece there. Pm'ed you.
Old Jun 29, 2006 | 07:10 PM
Muckman's Avatar
Moderator in Chief
Cant he just run two vac lines to it? or T it off to both inlets?
Old Jun 29, 2006 | 08:24 PM
SOHC_MShue's Avatar
Default Re: (Muckman)
anybody know of a good electrical header or something for hooking these up to wires. Its a bitch soldering directly to the pins
Old Jun 29, 2006 | 09:05 PM
Default Re: (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">anybody know of a good electrical header or something for hooking these up to wires. Its a bitch soldering directly to the pins </TD></TR></TABLE>
Digikey has them
their online tech support will be able to get the part # for you
i aint at home so i cant get the part # since i already got some of those
Old Jun 29, 2006 | 09:58 PM
SOHC_MShue's Avatar
sweet thanx man
Old Jun 29, 2006 | 10:31 PM
Jaker's Avatar
Old Jun 29, 2006 | 10:38 PM
SOHC_MShue's Avatar
Default Re: (Jaker)
yes some connectors like that are exactly what i need.
Old Jun 29, 2006 | 11:04 PM
Jaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">yes some connectors like that are exactly what i need. </TD></TR></TABLE>
Uh... The wires are soldered to the pins. I was just offering up an alternate mounting solution for the Motorola 2.5 bar. I don't think its designed for the engine compartment environment.
Old Jun 29, 2006 | 11:31 PM
SOHC_MShue's Avatar
Default Re: (Jaker)
oh woops i thought you had some little metal female fasteners that you used and then soldered on top of. Just looked that way from the pic
Old Jun 30, 2006 | 12:00 AM
mtber's Avatar
Single port 2.5 bars for sale:
https://honda-tech.com/zerothread?id=1673905
MPX4250AP
Old Jun 30, 2006 | 11:33 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
theres your problem
Makes sense, i was going to order one a long time ago, but they were out of stock then too... oh well.
I will update this later tonight, once i find the wiring procedure, and let you guys no how the dual port works out
Nice adapter too by the way.
Old Jun 30, 2006 | 12:40 PM
nerdsports's Avatar
i bought mine from this guy...
https://honda-tech.com/zerothread?id=1586636
Old Jun 30, 2006 | 01:31 PM
splitime's Avatar
Default Re: (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">Single port 2.5 bars for sale:
MPX4250AP </TD></TR></TABLE>
Woah, supply and demand at its finest! 18buck sensor becomes almost 60 buck sensor...
And you forgot TurboEdit on the supported list
Old Jun 30, 2006 | 03:26 PM
mtber's Avatar
Default Re: (splitime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime &raquo;</TD></TR><TR><TD CLASS="quote">Woah, supply and demand at its finest! 18buck sensor becomes almost 60 buck sensor...
And you forgot TurboEdit on the supported list </TD></TR></TABLE>
Old Jun 30, 2006 | 06:18 PM
Default Re: (mtber)
Update.....
Seems fine, idles, haven't driven it yet. No CEL or anything.
I have to scale my maps in Uber, that 8psi jump is a little much
I'll post up tommorow if it runs normal, right now i just have one of the ports open, i couldn't blow through it, so i'm assuming it'll be okay, i'll have to data log and see tommorow though.
Old Jun 30, 2006 | 07:10 PM
HiProfile's Avatar
I saw somewhere the 'DP' isnt for dual port, its for differential. 'AP' is absolute. My guess is it takes the difference from current air pressure on one nipple, rather than from the calibrated 0bar the 'AP' versions do. Take a multi-meter to the leads, turn the car on, and blow very hard into the open port.
Meaning... it could be iffy at best. High speeds that increase underhood pressure could affect it, as could cabin pressure (if it's inside).
As for availibility, a few places seem to still have them, but they aren't exactly retail places. I also saw some pdf on a 'plating change' sch'd for last nov-dec on many of that type of sensor, my guess is they fubar'd something.
Old Jul 1, 2006 | 07:41 AM
Default Re: Digi Key map sensor - Two nipples :O (HiProfile)
well that makes sense too, i like the dual port better
So, what if i just capped that port off, wouldn't it just see 0 pressure then? Or am i being too simple minded on that one.
Old Jul 1, 2006 | 10:34 AM
Well, i tried it, and it'll idle for the most part, but hit the gas, and no go, just dies. Tried a couple of different maps, went back to my old map, and stock map, and no issues, so who knows. Anyone explain how they figured out the wiring on the proper map sensor. It has the notch in one of the pins, so i'm assuiming thats number 1.
