B16 TURBO SETUP------------HAVING PROBLEMS PLEASE HELP
Old Jun 28, 2006 | 06:35 PM
WorkedDelSol's Avatar
Default B16 TURBO SETUP------------HAVING PROBLEMS PLEASE HELP
ok i have a delsol with a b16a3 in it with a turbo kit, im not spooling up and the boost isnt registering on the guage........what could be the problem
my setup is
b16a3
gsr cams
teflon coated stock pistons
skunk2 all motor valve train
aem cam gears
t3t4 ballbearing
obx manifold
hks ssqv bov
spearco fmic
spearco piping
all lines and other little things
msd retard...didnt use it though
manual boost controller
stock fuel rail, and pump
450 injectors
if anyone has any advice it would be a big help..................
Old Jun 28, 2006 | 07:54 PM
ghostskinner's Avatar
Default Re: B16 TURBO SETUP------------HAVING PROBLEMS PLEASE HELP (WorkedDelSol)
you might have a massive boost leak or your gauge isnt working
Old Jun 28, 2006 | 10:12 PM
quicksilver1689's Avatar
i ♥ snails
check the charge piping, wastegate and the actuator, vaccum lines? BOV settins n what not.
Old Aug 27, 2006 | 10:41 AM
w0ng_sta's Avatar
Default Re: (quicksilver1689)
um wastegate? forgot to list it i hope.. unless u internally wastegated... but if not then make sure ur wastegate isnt getting stuck open.. that would lead to the "massive boost leak" fo sho
Old Sep 8, 2006 | 07:42 AM
w0ng_sta's Avatar
Default Re: (w0ng_sta)
is your guage hooked up to the manifold? make sure it isnt pinched. also.. check your boost controller.. if you have it set for very low boost.. well you might not feel boost haha.
xlasianizelx
Aug 19, 2009 09:15 PM
asianspeed
Mar 1, 2006 09:34 PM
hybrid_204
Sep 5, 2005 08:24 PM
Realvibez
Jan 8, 2004 07:21 PM
blackfrohatch
Aug 26, 2003 06:47 AM
