what would be best
Old Jul 2, 2006 | 12:46 PM
JDM_EK_621's Avatar
Default what would be best
ok guys i am going to do a boost build motor over this summer and winter and i am just wanting some inputs on what motor would be best. along with some pics of what you guys are running.
i know a D16 is cheap and fun but i am lookin for some good power numbers here.
the motor will be going in to a 96-newer hatch.
right now i am running a b16a all motor build that is putting out 285whp but thats not good enough and thats in my 96 civic LX (4 door)
the one motor i know i dont want to build is an LS/Vtec
Old Jul 2, 2006 | 12:54 PM
B18 CYA's Avatar
Default Re: what would be best (JDM_EK_621)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EK_621 &raquo;</TD></TR><TR><TD CLASS="quote">
right now i am running a b16a all motor build that is putting out 285whp but thats not good enough :
50 bux says ur not putting that much out all motor
Old Jul 2, 2006 | 03:10 PM
JDM_EK_621's Avatar
Default Re: what would be best (B18 CYA)
ok so i left out the part about the 75 shot of Nitrous
so its truly putting down some where like 210-220
Gen 3 B16A
B16a PR3-3 Head
ITR intake Valves
Skunk2 Exhaust Valves
Skunk2 valve springs and titanium retainers
CTR PCT pistons w/ honda rings std. bore (81mm)
ARP rod Bolts
ARP head studs
OEM head gasket, used 1 piece
Skunk2 Stage 2 cams and gears
Skunk2 Intake manifold
ITR throttle body
RC 310cc Injectors
AEM fuel rail
CTR N-1 crank Pulley
P28 ecu from phearable.net
and then the back up 75 shot of Nitrous
Transmission
'00 Si
Kazz LSD
ACT XACT Streetlite Flywheel
ACT Heavy Duty Clutch Kit with 6 Puck Race Disc
Old Jul 3, 2006 | 03:11 PM
JDM_EK_621's Avatar
at work BUMP
jdmjunkie8
Dec 31, 2007 07:44 PM
vtecstudent
Jun 22, 2006 05:20 AM
idra
Mar 17, 2006 03:53 AM
92CivicSIRhb
29
Feb 10, 2006 03:38 PM
itr1236
Jul 12, 2001 05:31 AM
