Russell AN fittings
Re: Russell AN fittings (sicones)
i use high temp teflon even if the situation doesn't require it. I just feel better about the connections throughout my engine bay.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">yea I used 4 brand new crush washers that came with the new fuel filter and hose kit, they way that AN fittings seal using teflon tape wouldn't do anything because they don't seal at the threads they seal on a like special beveled seam
Are they copper crushwashers? If you can get the thicker aluminum ones. I had a problem with a Civic leaking fuel filter. I swapped the crushwashers back to aluminum ones and it sealed up no problem. May be a similar scenario, or I'm just typing to type. GOOD LUCK!
Russel fittings are near the bottom of my preferred list.This is not to say they don't work,I just don't think they are as good (quality) as Aeroquip, or Earls.There is no good reason for the fitting to leak at the angled sealing surface no matter who makes them.I have had them leak at the swivels and had the toss them.I try to avoid the swivel styles if I can.
Re: Russell AN fittings (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR »</TD></TR><TR><TD CLASS="quote">Russel fittings are near the bottom of my preferred list.This is not to say they don't work,I just don't think they are as good (quality) as Aeroquip, or Earls.There is no good reason for the fitting to leak at the angled sealing surface no matter who makes them.I have had them leak at the swivels and had the toss them.I try to avoid the swivel styles if I can.</TD></TR></TABLE>
Modified by sicones at 6:46 PM 10/5/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamlegacy »</TD></TR><TR><TD CLASS="quote">
Are they copper crushwashers? If you can get the thicker aluminum ones. I had a problem with a Civic leaking fuel filter. I swapped the crushwashers back to aluminum ones and it sealed up no problem. May be a similar scenario, or I'm just typing to type. GOOD LUCK!</TD></TR></TABLE>
is it a compression fitting?? if so..your other side has to be a compression fitting as well, thats how they seal, and if you over tightn them they will leak! No teflon is needed, just compression to compression, the two taper ends meet against each other to seal!
Re: Russell AN fittings (iBrandon)
I elimated that whole dampening dealy cause i felt it sucked. The little brass part that sticks out the rail is threaded, and uses the same size fitting as the fuel filter.
