Tach breaking up issues...
Old Jul 2, 2006 | 04:06 PM
*Boostwerks*'s Avatar
Default Tach breaking up issues...
A couple days before we tuned my car, It started missing due to the infamous ignitor crap. So I swapped in my spare ignitor and the car runs perfectly, but the tach won't go past 3K. It will move smoothly up to 3K and then it seems like it hits a rev limiter, bounces a couple times and then just dies.
Whats weird though, is that I noticed that neptune was datalogging the correct RPMs. So I don't know if the problem is with the ignitor itself, or the tach somehow. I'm just not really sure how I should go about fixing this problem.
Old Jul 2, 2006 | 10:56 PM
Anyone have this problem before?
Old Jul 2, 2006 | 11:24 PM
abnaasefmb's Avatar
Default Re: (Bryson)
i got an extra tach i'll trade you for one of those sweet topmounts
check your wires and ground. and swap out the ignitor with a buddies good working one just to rule it out, but i don't think its the ignitor.
Old Jul 2, 2006 | 11:40 PM
eflove's Avatar
Default Re: (abnaasefmb)
it sounds a like you have a different problem then me but i had a "rev limiter" feeling at 3.5k checked for codes got a code 4 crank angle. its in the dist. replaced it and it went away. my rpm cluster used to kinda jump around a bit now its smooth again. just a thought
Old Jul 3, 2006 | 01:51 AM
D@nnY's Avatar
Default Re: (eflove)
the crank position sensor can cause that...mine always breaks if i rev the **** out of the motor....its in the distributor in obd1 obd2 is on the oil pump
Old Jul 3, 2006 | 05:58 AM
19sec beast's Avatar
Default Re: (D@nnY)
I have this same problem.
My car always breaks up on the dyno right when it happens also, but after that, everything is perfect.
On the dyno graph, it leaves it blank, like the car slips off the dyno, but the datalogger shows the RPMS perfect.
OBD2 car here. So check the crank position sensor on the oil pump?
Old Jul 3, 2006 | 06:59 AM
crxnj's Avatar
Default Re: Tach breaking up issues... (Bryson)
im not sure how obd1/2 is ....but when it stops revving at 3000revs that means its in limp mode...could be the timing,,or inside distibutor,......I dont know what else it could be..
Old Jul 3, 2006 | 07:02 AM
Default Re: Tach breaking up issues... (Mr.speaker)
You're not understanding...
The car drives fine. The only thing wrong is the tach goes crazy, looks like it's hitting a rev limiter and then sits at 0 RPMs while the rest of the car is functioning as it should.
Old Jul 3, 2006 | 07:05 AM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 19sec beast &raquo;</TD></TR><TR><TD CLASS="quote">You're not understanding...
The car drives fine. The only thing wrong is the tach goes crazy, looks like it's hitting a rev limiter and then sits at 0 RPMs while the rest of the car is functioning as it should.</TD></TR></TABLE>
oh sorry, i wasnt sure what he meant..
Old Jul 3, 2006 | 07:08 AM
Just thought I would clarify.
Old Jul 3, 2006 | 10:44 PM
Default Re: (19sec beast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 19sec beast &raquo;</TD></TR><TR><TD CLASS="quote">I have this same problem.
OBD2 car here. So check the crank position sensor on the oil pump?</TD></TR></TABLE>
Breaks up like its missing? My car runs perfectly, so I don't know how it would be the crank angle sensor.
Hrmm.
Old Jul 4, 2006 | 08:19 PM
PrettyLude's Avatar
try another good distributor bryson.
Old Jul 5, 2006 | 06:40 PM
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">try another good distributor bryson.</TD></TR></TABLE>
Yeah, I'm sure its the ignitor, but I'd rather not have to get another one. I have my MSD tach output, but I'm not exactly sure how I should try wiring it up. I just need to spend some time looking at my helms.
boostedteg15
Aug 4, 2006 06:55 PM
AMChev
Nov 1, 2005 05:49 AM
WhiteGSR95
Mar 29, 2005 08:11 AM
sir168
Mar 15, 2004 06:09 PM
