modified to fit?
Old Jul 3, 2006 | 01:11 PM
clemsonteg's Avatar
Default modified to fit?
I was checking out some manifolds and I came across a guy with a greddy manifold and he says that it has been modified to accept and t3. First off what would need to be done to get a t3 to fit onto what I assume would be a t25 flanged turbo outlet? Does the pic below looks like it has been modified to take a t3? thanks in advance
Old Jul 3, 2006 | 01:12 PM
RobbieG35's Avatar
12 Years Strong
Default Re: modified to fit? (clemsonteg)
You would have to cut the T25 off and weld the T3 flange on. Looks like a T3 flange to me.
Old Jul 3, 2006 | 03:21 PM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Re: modified to fit? (HybridHatch88)
That dosnt look like a flange that has been welded on...but its sorta hard to tell from the pic. It looks like they welded the bolt holes on the flange and re-drilled them to work with a t3. Not a bad idea...if thats what they really did
Old Jul 3, 2006 | 03:46 PM
shortyz21's Avatar
Default Re: modified to fit? (sCeRaXn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sCeRaXn &raquo;</TD></TR><TR><TD CLASS="quote">That dosnt look like a flange that has been welded on...but its sorta hard to tell from the pic. It looks like they welded the bolt holes on the flange and re-drilled them to work with a t3. Not a bad idea...if thats what they really did </TD></TR></TABLE>
yep.
saywhat
May 23, 2006 12:05 PM
oxSLEEPERxo
Welding / Fabrication
Dec 21, 2004 01:28 PM
Slammd Sol
Mar 18, 2004 04:52 PM
nitekidsef9
Jan 9, 2004 03:35 PM
Taikonaut
Dec 2, 2003 01:40 PM
