fuel cut too early problem
Old Jun 29, 2006 | 03:17 PM
alexsracing's Avatar
Default fuel cut too early problem
I have a d16z6 turbo hatch. running uberdata with p28
fuel cut is set to 7300 but car is fuel cuting at 6100
tryed 2 different ecu's, tryed my friends chip that goes to 7300 on his car but not mine. if I make the fuel cut at 8100 on the program the car will fuel cut at 7000.
im stumped.
Old Jun 29, 2006 | 07:44 PM
bump
Old Jun 29, 2006 | 07:51 PM
adseguy's Avatar
Default Re: (alexsracing)
Interesting problem. Post up the bin, it could be something stupid in the FTL stuff. I trust the signal coming from the distributor before I would trust the Tach.
I don't understand how you tested all of this? 2 ECU's? 2 chips? please explain better
Old Jun 30, 2006 | 04:38 AM
my friend has the close to the same setup and hes using a p28 socketed with uberdata. I tryed using his ecu and chip in my car and the same results . but it works perfect in his car
Old Jun 30, 2006 | 02:43 PM
up
Old Jul 1, 2006 | 11:51 PM
bump
Old Jul 2, 2006 | 02:26 PM
Old Jul 2, 2006 | 07:25 PM
Default Re: fuel cut too early problem (alexsracing)
Old Jul 3, 2006 | 04:36 AM
Old Jul 3, 2006 | 07:04 PM
Old Jul 4, 2006 | 12:02 PM
adseguy's Avatar
If you say your chip and ECU wrks in another car then that means it HAS to be something mechanical happening. Spark gap? Check your whole dizzy assembly. Come back when this is done.
Old Jul 6, 2006 | 04:37 AM
put a whole new dizzy and same results.
maybe the honda rpm gauge is off?
Old Jul 6, 2006 | 04:49 AM
Soccerking3000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexsracing &raquo;</TD></TR><TR><TD CLASS="quote">put a whole new dizzy and same results.
maybe the honda rpm gauge is off?</TD></TR></TABLE>
lol you think? this is a common problem with stock honda tach's they are really far off at high rpm, for example my tach reads 7800rpm at 7300rpm (have shift light set to 7300)
Old Jul 12, 2006 | 03:15 PM
Just put a new fuel filter and new spark plugs.
can the rpm diff on the stock cluster be 1500 rpm behind?
Old Jul 12, 2006 | 03:34 PM
SOHC_MShue's Avatar
datalog the rpm signal
Old Jul 13, 2006 | 03:07 PM
having trouble datalogging any p28 ecu with uber and the moates hulog usb cable.
it works on a friends p06
Powered By Garrett
Engine Management and Tuning
Jun 15, 2008 09:03 AM
Twisted Image
Mar 2, 2008 05:07 PM
mike93boost
Apr 11, 2006 09:15 AM
jerbear!
Mar 26, 2006 11:28 AM
havalilsi
Feb 20, 2005 02:58 PM
