wanted to make sure b4 i tried it...PSI question
i've read/heard that you can add washers between the turbo and the wastegate on internal wastegated turbo's to get more psi..is this true?..how do you add more psi's aniway?
Re: wanted to make sure b4 i tried it...PSI question (krazyhmongboi)
If the wastegate actuator is bolted to the bracket, then yes. You can add washers between the actuator and the bracket.
1. I don't deal with internal wastegates so I dunno about the washers idea. I do know you can get adjustable internal wastegates.
2. You add "psi's" with MaDD VTEK BOOST powa yo.
3. Search I am sure this has been covered (either on H-T or on google).
