Down pipe flange ? Will this fit and work w/ the gt35r
Currently I have the Sc44 with the 5 bolt flange to my 2.5inch down pipe, I have on order now a Gt35R .82 housing, I know that the down pipe flange is a 4 bolt flange my questions is will I be able to weld the 4 bolt flang up to my 2.5 inch down pipe that I have now or does it require you to get a 3" dp.
Re: Down pipe flange ? Will this fit and work w/ the gt35r (Turbo-LS)
sweet so does the one with the .82 trim size come with the 2.5 inch exhaust option or is it the .63 only
Re: Down pipe flange ? Will this fit and work w/ the gt35r (spoolingb20)
Like i said it depends on which housing they give you. The a/r size doesnt decide which outlet on the housing you have. Best bet is to call where ever you ordered it from and ask them if it has 2.5" or 3" outlet. I thought mine was comign with the 3" outlet but full-race used the 2.5 outlet housing insttead because they said they had fitment issues with the 3" outlet housing with my turbo. GT3567R
Which coolant supply line did you use and which one did you use for the return?
i have a blox intake manifold which had a small coolant port below the large out that comes off the head. i used that to feed the turbo and the return is tee into the return hose from the iacv
eh eh guys i need help also i havent bought a down pipe yet and im welling to spend the money on a gt35r BB.
Compressor Wheel Exducer Diameter: 82MM - 56 Trim
Compressor: .70 A/R
Exhaust Wheel Inducer Diameter: 68mm - 84 Trim
Exhaust A/R: 1.06
i also just want a 2 1/2 down pipe and all the other pipings are like 2 inch only. i do want to custom 3 inch piping or 2 1/2 piping but its gonna cost me. so i went for a cheap way.
if any one knows anything about the piping fitment for gt35r BB please help me out. first time going turbo so yea kinda noob.
Compressor: .70 A/R
Exhaust A/R: 1.06
Compressor: .70 A/R
Exhaust A/R: 1.06
BlueShadow
07-31-2005 09:10 PM
BoostedH23a1
04-26-2003 12:00 AM
W.Zero
03-12-2003 09:58 PM
