so when is a 3" exhaust really needed???
Old Jul 1, 2006 | 10:21 PM
.adam.'s Avatar
Default so when is a 3" exhaust really needed???
so im nearing the end of my build and right now i have a apexi ws2 exhaust. my basic setup consists of a gsr engine and tranny with low comp wisecos and eagle rods along with a gt3076r. how much of a power gain would i see with a 3" compared to using the world sport2(2.25")?
Old Jul 2, 2006 | 04:33 AM
nickromeo's Avatar
Default Re: so when is a 3" exhaust really needed??? (civicskater)
better spool up with the 3'', if u want to push high power get the 3''.
i did on my sohc made a world of difference
Old Jul 2, 2006 | 05:51 AM
oscarmayer's Avatar
if your running a gt30R you NEED a 3" peroid. no ifs ands or butts.
a gt28R can get away with 2.5" on 10 lbs fo less, but not a gt30R.
Old Jul 2, 2006 | 06:26 AM
N20civicB18's Avatar
Default Re: (oscarmayer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oscarmayer &raquo;</TD></TR><TR><TD CLASS="quote">if your running a gt30R you NEED a 3" peroid. no ifs ands or butts.
a gt28R can get away with 2.5" on 10 lbs fo less, but not a gt30R.</TD></TR></TABLE>
word
Old Jul 2, 2006 | 11:28 AM
eastbay92cx's Avatar
Default Re: (N20civicB18)
With that turbo, a 3" would be a big plus. I want to say somewhere around 250-300whp, you'd start to see some real gains with the larger exhaust. "2.25 would be more appropriate for an all motor setup, ~220hp.
Old Jul 2, 2006 | 12:10 PM
JDM_Risa's Avatar
werd x2
planning to go 4" soon hahaha on my daily driver
Old Jul 2, 2006 | 01:58 PM
RedEj8's Avatar
Default Re: (JDM_Risa)
https://honda-tech.com/zerothread?id=1309873
Just get a 4" like this
Old Jul 2, 2006 | 07:52 PM
HiProfile's Avatar
Well consider the fact that 3" has 77.8% more interal volume than 2.25", as well as typically having larger-radius turns. Due to the backpressure of the turbine housing/wheel, I believe in doing whatever you can to reduce exhaust backpressure. Hell, I'm running full 3" dp/exhaust on a stock d16z6 w/bad oil pump & smallish s-trim w/internal WG. Spools very quickly for what it is.
Old Jul 3, 2006 | 07:16 AM
Topdawgg's Avatar
the WS exhaust is nice with an N/A application, but i had it on my boosted motor and hated life... it LIMITED ME hard....
im runnin a 3 inch now..
Old Jul 3, 2006 | 05:02 PM
QuarterMileMaster's Avatar
Default Re: (Topdawgg)
Keep your stock exhaust and get an e-cut out installed.
http://www.dmhperformance.com
4 year warranty, great product and works beautifully and no hassels with full 3"
Heck of alot cheaper too. My .02
Old Jul 3, 2006 | 05:13 PM
Mag00n's Avatar
Default Re: (QuarterMileMaster)
there are 400+hp factory cars running 2"- 2.5" pipes
its not about NEEDING its about wanting the "free" horsepower
yes there IS a point where you 'need' a 3" but for most of us its just more power
Old Jul 3, 2006 | 05:36 PM
HamiltonRex's Avatar
Default Re: (.m a c a)
If funds permit run a 3" setup.. Its worth it.
I went with a Kteller stainless weld up kit.. Bough a 3" sidemount magnaflow, and by the time i bought my cat, downpipe material, flanges etc etc.. I spent around $650 in material, and its a full stainless exhaust so it should last.
I wouldnt recommend Kteller for anything but the exhaust kit, the other parts can be found much cheaper elsewhere.
Old Jul 16, 2006 | 06:21 PM
boostmywankle's Avatar
Default Re: (HamiltonRex)
wait, is this just for the 4dr teg?
Old Jul 16, 2006 | 07:40 PM
GS-R Civic's Avatar
Build a 3" system around the muffler im selling in the sig \/
It sounds really nice on a turbo car, not ricy and beehiveish
Old Jul 16, 2006 | 09:42 PM
.adam.'s Avatar
ive seen those go for less on ebay new
Old Jul 16, 2006 | 09:49 PM
MidShipCivic's Avatar
Run an exhaust cut out and advoid the noise on a switch.
Old Jul 16, 2006 | 09:55 PM
GS-R Civic's Avatar
Default Re: (civicskater)
$145 with shipping
http://cgi.ebay.com/ebaymotors...wItem
sorry don't mean to jack i just needed to respond to your response
and a free bump for you!
Old Jul 17, 2006 | 03:21 AM
1epmugenlude's Avatar
What do you all think, would a 3" exhaust be overkill for a prelude with just a greeeeedy turbo kit running 13lbs boost?
Old Jul 17, 2006 | 06:34 AM
fracas's Avatar
Buy a Kteller exhaust from Kteller8 here on the boards. Quiet system with a Oval Magnaflow muffler.
Old Jul 17, 2006 | 06:47 AM
GS-R Civic's Avatar
Default Re: (fracas)
thats what i have
Old Jul 17, 2006 | 07:10 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .m a c a &raquo;</TD></TR><TR><TD CLASS="quote">its not about NEEDING its about wanting the "free" horsepower</TD></TR></TABLE>
That's right. 3" exhaust is always better, no matter what turbo you have.
Old Jul 17, 2006 | 07:19 AM
GS-R Civic's Avatar
Default Re: (RyanEJ8)
and faster spool up is nice!
Old Jul 17, 2006 | 08:13 AM
JDogg's Avatar
Default Re: (GS-R Civic)
there is no such thing as overkill when it comes to exhaust size on a turbo car, bigger is always better
Old Jul 17, 2006 | 08:25 AM
RyanEJ8's Avatar
Default Re: (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">there is no such thing as overkill when it comes to exhaust size on a turbo car, bigger is always better</TD></TR></TABLE>
That's right. I plan on going with a 7" exhaust for my new setup.
Old Jul 17, 2006 | 08:34 AM
JDogg's Avatar
5inch is about the biggest that will fit between the tranny and the radiator...
