Turbo makes loud whirring sound, Brand new?
Sup folks, just got done doin a turbo install on my buddy's F22. Took the car out for the initial test drive an its makin a "whirring" sound as it revs up and maybe a metal grind (but that could be other thing on the setup). Also, it wouldnt hit boost immediately (unless maybe the guage doesnt have a good vaccuum source) it will be going, at full throttle and all of a sudden i'll have 6psi. The sound definately seems to be coming from the center section of the turbo, it spins fine, its getting oil, and only has minimal normal side-side shaft play. But that noise is scary, almost like turnin on a mini-vac or somethin. Suggestions as to what it might be? I'm taking it apart right now and will post back, and have pics once i do that.
Heres the sweet vid http://media.putfile.com/This-turbo-is-hostingd
Modified by 90LSpimpin at 4:30 PM 6/30/2006
Re: Turbo makes loud whirring sound, Brand new? (90LSpimpin)
Took it apart. The turbine side wheel looks minty, half of the turbine housing looks darker than the other half, maybe heat issues? The compressor housing is fine, but some of the fins on the compressor wheel are slightly flattened at the edges like it was grinding the side of the walls. So that pretty much isolates the problem. Why might this have happened? the car ran for no more than 30 mins last nite, most of which was idle, and the engine and turbo were well primed, i cranked it over for a few mins before actually letting it start. Again turbo is brand new, from ebay, and its not a SS.
Re: Turbo makes loud whirring sound, Brand new? (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy »</TD></TR><TR><TD CLASS="quote">You sure it was not a rebuild? Is the Garrett tag red or green?</TD></TR></TABLE>
No Garret tag, turbo came from user Down2Turbo on ebay. Had another friend buy a turbo from him and has had no problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RogueWorks »</TD></TR><TR><TD CLASS="quote">send it back to the seller for warranty repair</TD></TR></TABLE>
That looks to be the next step, cus this thing has literally 0 miles on it.
my fins hit on my crappy ebay turbo. the guy lied on the listing saying it was a garrett turbo. you are prob in the same boat I was in. I would do everything possible to get a refund.
1 Post
Re: (PhantomX)
my turbo makes a "whirring" sound, but that's because i'm running open DP. so that's how the turbo sounds like. about the the noise that seems like it's metal grinding against something, try checking your gaskets. could be a little air leak from the wastegate or something
Re: (itsJDMyo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itsJDMyo »</TD></TR><TR><TD CLASS="quote">my turbo makes a "whirring" sound, but that's because i'm running open DP. so that's how the turbo sounds like. about the the noise that seems like it's metal grinding against something, try checking your gaskets. could be a little air leak from the wastegate or something</TD></TR></TABLE>
Did you watch his vid? Its not what your describing lol
Re: (itsJDMyo)
How do you know your getting enough oil? I used a restrictor adjuster, and if i turned it down too low, when i revved it up, it would do what yours did.
Re: (coneheadsracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coneheadsracing »</TD></TR><TR><TD CLASS="quote">How do you know your getting enough oil? I used a restrictor adjuster, and if i turned it down too low, when i revved it up, it would do what yours did.</TD></TR></TABLE>
Theres no restrictor, and its getting oil. Shaft doesnt spin straight at all whe its rev'd up. hes just ordering another turbo. sux
Re: (PhantomX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhantomX »</TD></TR><TR><TD CLASS="quote">your shaft is probably bent..... same thing happend to me.... damn ebayTurboz</TD></TR></TABLE>
damn down2turbo / mjm auto/ ebay specials
they're rebuilt by mjm auto down in some hick town.
not MJM turbo <!~~ good company ..
i've went through 5-6 turbos with this same problem all from the same person. ( down2turbo) when i first started.. junk !!
Re: (komat)
Ran the super jdm screen on both of my setups in the last 2 years
never had a problem
i have more room on my new setup on the teg, so i will soon be making an intake for it
never had a problem
Re: (komat)
At that point, i dont think it was on very much, i had jsut slipped it back on so i wouldnt lose it. I wanted to look at the wheel spin directly, when it starts makin that noise, that ****** spins wild lol
abmerop18
03-27-2006 05:53 AM
