SOHC Greddy turbo manifold. need a B18 manifold that works
I have a Greddy turbo kit off a D16 civic and i have a B18 LS in my civic what exhaust manifold can i use to bolt up to the 15G turbo?
Re: SOHC Greddy turbo manifold. need a B18 manifold that works (carma42)
does anybody know at least what the flange is that is on the greddy turbo that coomes in their kits?
come on i have read and read with so many posts that go all different directions. is it the T25 flange on it or what?
Re: SOHC Greddy turbo manifold. need a B18 manifold that works (R1Motorsports.com)
thank you very much. so i can go on ebay and order a B18 T25 Manifold and that turbo will bolt up? just checkin .
Yeah the turbo will bolt up to a T25 manifold, but watch the placement of the flange. If it isn't close to where the flange was on the Greddy manifold, it will throw off your downpipe, IC pipes and might not fit without removing the AC comp.
the only problem i am seein is that the turbo i have has holes in it not studs and the SOHC greddy manifold has the bolt studs on it. so any of the manifolds i have found have had the holes on them which the setup i have needs studs on the manifold. does this make sense? if not i can post pictures.
maxoutracer
08-02-2005 05:41 PM
dingusjt
02-11-2004 02:18 AM
