air filter for my turbo
alright i have a boosted b18 motor with a t3 super 60 turbo on it, the turbo was so big that i had to shave some of the block to make it fit, but my problem is now with the 3" inlet there is no clearance to put any piping to atatch a filter because the fans are so close....my question is.....ive heard of a type of filter you just atatch straight to the turbo inlet side and its just a flat filter made to fit different sizes i know this might not be as good but does anyone know where i can find one?
Re: air filter for my turbo (rdssk8rcs1)
Try to stay away from those foam mushroom looking ones, a while back someone posted a large restriction on the dyno due to one, and I think someone else said their turbo sucked one in and broke the turbo.
If you don't want to fab up an intake tube and put a filter where you can fit it, try different sites (atpturbo, ebay, i have no idea really) for a type of filter you are looking for, or last resort you can always run a screen. good luck
Re: air filter for my turbo (eastbay92cx)
yeah im running a screen right now but there is only so much that does
what i was trying to explain before is something along the same lines as what a screen does but its more of a filter....someone was telling me about them......not the mushroom ones
I have the same problem, I just installed a turbo in my b18 and had to shave the block in order for it to fit. Its impossible for me to fit a filter on the turbo because it hits the little bar thing that comes off the tranny. Anyways I would really like to know where to get one of those too.
Re: air filter for my turbo (95dc2teg)
disconnect the bracket and leave it hanging...its supported on there enough once the filter is jammed in there! works like a charm
I had a similar problem with my Revhard setup. I ended up buying a 45-degree silicone elbow with a 3" inlet. The silicone is flexible enough that it bends in a little where the clutch bleed valve pokes out.
I bought a K&N universal filter with a 3" inlet, and used a short section of 3" aluminum pipe as an interior coupler for the elbow and filter to clamp onto.
Elbow was from ATPturbo.com, if I remember right. Used their T-bolt clamps too. You can check through K&N's site to get a part number and order from your local autoparts store.
jon volk
Welding / Fabrication
02-22-2006 07:36 PM
Dan_the_MaN
11-17-2005 12:31 AM
ZCHF
04-22-2003 08:46 AM
