knockoff bov on ebay
Old Nov 13, 2006 | 03:02 PM
leinadmiih00's Avatar
Default knockoff bov on ebay
anyone use the knockoff bov's on ebay? are they any good?
Old Nov 13, 2006 | 03:09 PM
RCautoworks's Avatar
Default Re: knockoff bov on ebay (SickMyDuck)
Last customer used one, was the type S greddy one. It sucks, it leaked and really did not blow off
Old Nov 13, 2006 | 03:31 PM
BoostedB16EJ's Avatar
Default Re: knockoff bov on ebay (90blackcrx)
i tuned a customer's integra and he had an ebay HKS knockoff SSQV. it had some carbon fiber wanna be sticker lookin coating on it. anyways the car hit a boost spike ( 15 psi) and the valve literally cracked almost OFF the flange!. now granted im sure that they all arent HORRIBLE like that, but that definately made me weary.
http://www.nopionline.com/nopi...20ONE
that's nopi's house line ( number one performance) blowoff valves. ive had a few customers use them and seem pretty impressed for low boost applications.
Old Nov 27, 2006 | 04:05 AM
tweekerz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Last customer used one, was the type S greddy one. It sucks, it leaked and really did not blow off </TD></TR></TABLE>
I just removed the inner (smaller) spring and left the outer (larger)spring installed on that greddy type s knockoff that 90blackcrx is talking about. It works fine now. Sounds close to the real type s, but no cigar. I'm going back to my authentic Greddy type RS but will be removing the inner spring as well on it.
Old Nov 27, 2006 | 04:53 AM
Mr.60trim's Avatar
From: What Business is it of yours where Im from Friendo
Default Re: knockoff bov on ebay (tweekerz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tweekerz &raquo;</TD></TR><TR><TD CLASS="quote">I just removed the inner (smaller) spring and left the outer (larger)spring installed on that greddy type s knockoff that 90blackcrx is talking about. It works fine now. Sounds close to the real type s, but no cigar. I'm going back to my authentic Greddy type RS but will be removing the inner spring as well on it. </TD></TR></TABLE>
Why did you remove the inner spring? I'm planning on getting a real type-S bov so I'm kinda curious.
Old Nov 27, 2006 | 05:20 AM
tweekerz's Avatar
Default Re: knockoff bov on ebay (Team_Carnage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team_Carnage &raquo;</TD></TR><TR><TD CLASS="quote">
Why did you remove the inner spring? I'm planning on getting a real type-S bov so I'm kinda curious.</TD></TR></TABLE>
Yeah your gonna have to. I was getting compressor surge on my both bov's with both springs installed. Removing the inner spring on my knockoff type s stopped the compressor surge... im sure it will work on the Greddy.
Old Nov 27, 2006 | 05:29 AM
tweekerz's Avatar
Removing the inner spring reduces the amount of tension it takes to move the piston up and down... i'm guessing that 7psi wasnt enough to get that piston moving.
Old Nov 27, 2006 | 05:31 AM
SPOOLINmatt's Avatar
how about those knock off tials. not much to break on those?
Old Nov 27, 2006 | 05:53 AM
Schister66's Avatar
Man U FTW
just get an authentic Tial and call it a day....no worries....ever
Old Nov 27, 2006 | 06:06 AM
99B16Si's Avatar
i took apart the knock off greddy type s i had along wiht a real type s and it was exactly the same as a real type s other than the diaphram. the knock off used a brittle rubber o ring and a rubber sandwich gasket to seal up the internals.....bad design which i am sure leaked
Old Nov 27, 2006 | 06:10 AM
b18sihatch's Avatar
Default Re: (Schister66)
x2
Old Nov 27, 2006 | 06:18 AM
CRXDrew's Avatar
seen more than a few ebay "RFL" style bovs work flawlessly
Old Nov 27, 2006 | 06:21 AM
tweekerz's Avatar
Default Re: (99B16Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99B16Si &raquo;</TD></TR><TR><TD CLASS="quote">i took apart the knock off greddy type s i had along wiht a real type s and it was exactly the same as a real type s other than the diaphram. the knock off used a brittle rubber o ring and a rubber sandwich gasket to seal up the internals.....bad design which i am sure leaked</TD></TR></TABLE>
Havent taken apart the authentic Greddy Type RS yet but it seems to be much better quality then the fake. The fake had some cheap rubber that could cause some leaks overtime.
Old Nov 27, 2006 | 06:23 AM
aaronISthrowed's Avatar
Default Re: (tweekerz)
I would just get a real TiAL.
Old Nov 27, 2006 | 06:56 AM
tegracer877's Avatar
Default Re: (aaronISthrowed)
my greddy type rs knockoff has worked perfect for about 7,000 miles now $45 off ebay
Old Nov 27, 2006 | 07:06 AM
Default Re: (tegracer877)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegracer877 &raquo;</TD></TR><TR><TD CLASS="quote">my greddy type rs knockoff has worked perfect for about 7,000 miles now $45 off ebay</TD></TR></TABLE>
That seems like a good deal.
I never knew they were $45.00
Old Nov 27, 2006 | 07:13 AM
EJ1 wilcox's Avatar
I've seen a few diaphrams on the cheapo BOVs and they are not good at all.
IMO, if you are going to do a cheap BOV, either get one without a diaphram (like the RFL), or go with a 1st gen DSM, they are cheap and well made.
Old Nov 27, 2006 | 07:15 AM
Schister66's Avatar
Man U FTW
if you're going to go cheap, get the RFL since it has no diaphragm inside.....it has less chance to leak
Old Nov 27, 2006 | 08:53 AM
tweekerz's Avatar
Hey if anyone wants my 3 week old greddy type s knockoff, ill sell it for 25 shipped. Thats 50% off of ebay!1
RACEPAK
Mar 14, 2008 02:43 AM
vtec.dc2
Jun 24, 2007 02:05 AM
Wonk Unit
Jan 13, 2007 10:01 AM
95dc2teg
May 30, 2006 03:56 PM
integlspwr2k
Aug 2, 2004 02:49 PM
